instrument lamp(Oil,charging) - light on when ingnition on?
rioeni486
hi. I am onwer of v11 lemans 2002 in south korea.^^
I am sorry to say I am not that good in english. plz understand.
I have a question.
When the ignition on(not running engine), which lamp of instrument should be light on?
Of mine, only neutral lamp on.
Thanks.
With the key ON check the oil lamp by touching a wire connected to the chassis to the wire at the oil pressure switch, this should make the oil light go.
The oil pressure switches are very un-reliable.
Check the charging light by touching the same wire from chassis to the white wire at the regulator.
  • 3 weeks later...
Thanks all above reply.
Finally, all my lamps of dash working properly.
1.Oil check lamp : replace oil pressure switch(sender) - Trofom TF-3-008 (you can buy it www.aliexpress.com) - $7~8
2.Charing lamp(battery0 : Replace regulator(ESR515) - also overcharge(14~17volt) problem is fixed
