moto fugazzi Posted August 10, 2014 Posted August 10, 2014 After comparing BIN files on my 2001 V11S and an EV, they are almost identical except for the ignition map. Is there any reason I can't use the map on my V11S? The excessive pinging is driving me crazy, and after a day of trying the EV ignition map, I've had no pinging whatsoever, although the bike bike doesn't seem as "peppy". I could also run some lower octane fuel as a result of this since fresh premium grade petrol is hard to find in Milwaukee. Here's the ignition map postings. V11S map EV map Difference
Angelo.M Posted August 10, 2014 Posted August 10, 2014 Seems like too much advance is removed . Usually a couple or three degrees less does the trick .
