stewgnu Posted August 12, 2014 Posted August 12, 2014 Hi All, Am I correct in thinking that the torque figure for the head cover bolts is 8 - 12NM? I'm buttonin her back up tomo after a valve check... Ta in advance, Stew.
LowRyter Posted August 12, 2014 Posted August 12, 2014 just a tug and click of your allen wrench should do the trick.
docc Posted August 12, 2014 Posted August 12, 2014 Stew, Yeah, 6mm screw: 8-12 NM. I've always wire brushed my threads and treated them to a dab of copper anti-seize. Wipe the gaskets and head surface clean. Tighten in a "star" pattern from the inside > out. Same gaskets after 90,000+ miles! (FWIW, I use LowRyter's "tug-squinch" method for the torque using a T-handle . . .)
vuzzi Posted August 13, 2014 Posted August 13, 2014 There is a lot of discussion about using copper paste on alu / steel connections. It may cause electochemical corrosion. The head cover bolts on my bike always have some engine oil on them. They never get stuck. I also rub some engine oil on the gasket and use the gasket time after time
stewgnu Posted August 14, 2014 Author Posted August 14, 2014 Cheers folks! All back together, no leaks. Still getting slight rough patch around 2500 - 3000 revs though... kinda feels like a pulse backing up thru the system. I'm starting to ride around it but that part of the revs is exactly where I find myself when accelerating out of roundabouts/slow corners. Wonder how that other chap with the surging Ballabio got on.....
fotoguzzi Posted August 14, 2014 Posted August 14, 2014 if you still have the stock crossover that might be the source of the rough patch. changed mine to a Mistral x-over and the cough, hesitation I had (3200rpm) went completely away.
stewgnu Posted August 14, 2014 Author Posted August 14, 2014 There's the mistral crossover and titanuim cans on her at the mo. I've been suspecting air leaks ever since the left throttle body got blown off. I suppose next step is 2 safety pins and a look at the tps reading- which is what t'other chap (lugs) was about to sort. At least it aint stopping me riding it though!
