andrei Posted September 1, 2014 Posted September 1, 2014 2004 LeMans . Starts no problem ( cold ) idles quite well , won't rev much above 3 k , starts surging , running on one cylinder , stalls as she warms up , stalls , Any ideas ?
andrei Posted September 1, 2014 Author Posted September 1, 2014 At first I thought water in the tank , drained it , changed the air filter . No go .
czakky Posted September 2, 2014 Posted September 2, 2014 Start simple with spark plugs, then coils. Have you been through the TPS and Throttle Body setup? Is it a new to you bike? Was it running good?
andrei Posted September 2, 2014 Author Posted September 2, 2014 Not new , had it for the last 6000 miles . it was running fine , went on a 1500 mile trip a while back , didn't miss a beat . Going to Walmart to pick up some plugs shortly . Noticed that when I work the left injector manually , it revs better than the hand-throttle ? Sounds like Throttle bodies , TPS maybe ?
andrei Posted September 2, 2014 Author Posted September 2, 2014 Plugs were dry-fouled black as coal . Changed them . Same thing .
moto fugazzi Posted September 2, 2014 Posted September 2, 2014 Are both plugs black? How long did it take to get to that blackness? Black normally means too rich, so I'm wondering if it's leaky fuel injectors (chances of both of them leaking should be low) or a bad fuel regulator. If it was just one side, I would think maybe a bad coil. If you take off the caps on the vacuum ports where you connect the hoses to balance TB's, how much fuel pours out of those? FWIW, you can buy a fuel pressure tester from HF http://www.harborfreight.com/fuel-injection-pump-tester-92699.html And I think if you need a new regulator, you can pick them up from your local H-D dealer for pretty cheap. Ken 1
luhbo Posted September 3, 2014 Posted September 3, 2014 Temperature sensor? It's the blue part on the right cylinder. Look for disconnected cables first, then measure the sensor's resistance both hot and cold. You'll find the correct values in the shop manual. Hubert 1
moto fugazzi Posted September 3, 2014 Posted September 3, 2014 I'd recommend getting Guzzidiag so you can check any faults within the ECU. If you're handy with a multimeter, go with Huberts idea. How long did it take the plugs to go black from completely new? Ken 1
andrei Posted September 5, 2014 Author Posted September 5, 2014 Checked the plugs in June they were fine . Got spark , got fuel . And on it goes .
