This write-up was pitched at another forum which have a mix of rider abilities. However, thought you guys might like to read of and see a V11 being put through it's paces like I am sure many of you do too.
My track day starts weeks prior to the day itself. I read up on my forum posts from previous visits to a track or look around for similar written by others if I am going to a new track. Having been to Cadwell twice before, I have two previous reports to refer to. From them I can refresh my memory of lessons learned and save time in the morning relearning them. Things like using your knees and feet down Mansfield and that a time consuming wheelie can accidentally be made over the mountain.
Then there is prepping the bike and getting accustomed to it. The V11 is very different from the 750 Breva and a good ride round Wales with Glen, Graham, Bloke and briefly Pip allowed me to scuff in the new tyres and get in the groove with the gearbox. Thanks for your company that day fellas.
So off to the track, registration, noise check and into the briefing. The BMW track days organised by Robert Bensley are quite unlike typical track days, bikes fully MOT worthy only and mirrors to be left on. The reason for this is because there is such a spread of machines from the S1000RR HP4 to classic R100RS of the 1990s. Now there are some quite tame riders on the later kit, whereas on the older kit there are some fast riders that can lap quicker. So for safety reasons out of turn 18 and turn 3 riders are briefed to check their mirrors for lower powered machines on their tail and let them through on the straights. This aims to prevent risky overtaking on other parts of the track and make the event a friendly safe gentlemanly day.
So to the lap, and out of turn 18 onto the start/finish straight, moving up through the gears to top whilst moving to the right of the track. Just dip the throttle slightly and tip the bike into turn 1 Coppice on the throttle and allow the bike to drift to half way out across the track up the hill after the apex, the gradient overcoming the drive from 6th gear. Pull the bike back to the left and throttle off changing down to 5th preparing for the blind turn 2. Glance at the marshal’s pillbox checking for a flag, and tip into Charlies 1 on the gas again allowing the bike to drift to the left after the apex find the turn in cone for turn 3, the combination of limited power due to lean and gradient further shedding speed. Spot the turn 3 turn in cone passing over the brow and throttle off and down to 4th gear. Look for the apex cone and power down through the bend in 4th allowing the bike to drift back out to the left if the track is clear dropping a mirror check, or keep it tighter if looking to pass. Along the Park straight working the box up to top, then there are three marker boards for Park bend turn 4. Riding with space, roll off the throttle at the 1st marker toward the left of the track, and use of the brakes for the first time in the lap at the 2nd board moving down to 4th gear before the turn in cone. Power through turn 4 in 4th gear, drifting wide, then nurse the throttle into turn 5 “Chris 1”, again drifting wide to prepare for “Chris 2” turn 6. Backing the throttle off a little, still in 4th gear, cling to the right side of the track, then flicking the bike to the left through the “Gooseneck” and a squirt of power down the hill toward Mansfield. One third of the way down the hill, clench the tank with the knees, press on the foot rests, and for the 2nd time in the lap, on the brakes firmly whilst keeping the elbows flexible, shifting down to 3rd gear. A squirt through and out of “Mansfield” turn 8, drifting out to the right still on the power and hauling it back toward the left on the brakes for the 3rd time. 3rd gear through the chicane turns 9&10, and powering off up into 4th gear towards turn 11. Braking again from 4th down to 3rd for the left turn 11, leaving the turn in late to keep the apex late and tight and slowing, before flicking right and squirt up the mountain in 3rd maybe feeling the front go light as the bike gives a little wheelie and into 4th passed the clubhouse. Tight to the left, nurse 4th gear through “Hall bends” and down to 3rd and hard on the brakes for turn 17 “The hairpin”. Up to 4th and carefully pitch into turn 18 “Barn” down the hill back onto the start finish/straight glancing in the mirror and around to check for other riders having caught up
10685500_805299072855835_866837140010553
10358559_805299129522496_717765117902171
10394101_805299122855830_225241419976605
10352979_805299192855823_450259567344258
Now in every group there is someone that thinks they know better than the briefing notes and on this day it was rider X on a BMW S1000. On a more powerful bike than I, I drew alongside him at various points of the track in the 1st session, only for him to open it up on the straights and waste me. Myself getting faster lap on lap, suddenly along the start finish straight the gap between us was much less than previous laps and rider X braked going into turn 1 leaving me no option but to go underneath him just prior to the apex. Half wondered if I would get my collar felt by Robert for that. Anyway I was well clear by the time I entered park and just cleared off up the track. After the session I did collared an instructor and explain that “bulking” was going on.
Session two and again I found myself in the company of rider X. More patient this time not wanting to sink to his level, I followed him until going through “Coppice” two riders came cleanly barrel arsing round the outside of us going up the hill. This upset Rider X going into Charlies1 and he lost that much momentum, I rode round the outside of him and again disappeared off up the road, safely still in front going into Park.
The 3rd session and again having drawn alongside Rider X out of Barn, he wasted me on the straight, and having witnessed the pass round the outside of Coppice in the previous session, I mimicked it to good effect performing a clean pass on him up the hill toward Charlie1. Session four I nailed him between marker boards 1 & 2 for another clean pass. Prior to lunch I mentioned him by number to an instructor.
Post Lunch brief and Robert again mentioned bulking and letting faster less powerful bikes through. 1st session out and rider X appeared not to have been in the post lunch brief. So, by the end of the day I had scalped him cleanly on Coppice twice, Charlies 1, on the brakes into Park, under him between Chris1 & 2, on the desent into Mansfield on the brakes and round the outside of him from Mansfield to the chicane and of course the unplanned messy one in to Coppice in the 1st session. Rider X must have had a very confidence dashing time with folk riding round him every which way as he refused session after session to play nice. I am a firm believer that respect and patience should initially be given to all, but whether they keep your respect and patience is up to them. However, for me as the day progressed I learned places where clean passes could be accomplished and built confidence.
Most riders were great and were a pleasure to ride with. One rider that really stood out was the guy on the R100RS. He was so smooth and quick. I could not stay with him. However in the paddock he did confess the bike was an ex-race prepared bike he’d come by and put back on the road.
One rider on a K1200S I followed for a couple of laps, although he was never in my way. I would nearly catch him through the twisties and he would ease away again on the straights and then I would nearly catch him on the next set of twisties. Finally curious, he waves me through and followed me for the rest of the session. After the session we spoke and he wanted to see the lines I was using to catch him, hence waving me through. He followed me again for a bit the next session, then wasted me on a straight. Put in to practice what he had seen and disappeared off into the distance, which I actually found satisfying.
10626599_805299242855818_420597755466964
10387231_805299269522482_177347166385608
10609538_805299312855811_372905568683136
1545016_805299389522470_8325735941034703
10403488_805299432855799_448604134972548
Tyres after the sighting lap . . .
10641027_805301882855554_350612293062627
10301354_805301876188888_251232194149835
10649690_805302176188858_111305569425667
10639440_805302349522174_637102354949312
14987_805302482855494_440965138642186037
1424470_805302649522144_2054960724259159
10703985_805302679522141_877397801241870
10671474_805302812855461_103601683796333
10710989_805302822855460_598203623189615
Thought I would add in pictures of my tyres and the vanishing logo as the day went on.
Not sure which part I like better the S1000 that couldn't hang with you, or the R100rs that was cooking those corners. Nice read, thanks for the write up.
Still some life in these old-ish girls!
You need to get off the bike more and get some value out of those knee scrapers and save the side stand. Get your toes on the pegs and tuck your feet in to keep your boots off the deck.
Try some road race boots as well, those big clod hoppers wont offer you much feel through the pegs.
:nopic:
I remember seeing previous pix you posted on track - looks like you're getting the hang of it!
Agree w Phil about the boots etc - I used to ride in german paratroop boots from army surplus - I got race boots, but still couldn't keep my toes out of the road, think you get a habit, then your body just fixes itself that way, I'm the same on a mountain bike...donald duck.
Maybe just take the sidestand off?
You're not wrong, but as Baldini mentions, I have moved on somewhat since my last visit and the level of progress and resulting conflict between tarmac, stand and boot was not anticipated.
Plus I only do one track day a year. Good to give the bike a proper airing thought. The new clocks are great on track. Must work out how to use the lap timer.
Enjoyed that, thanks :thumbsup:
Me too.  Thanks for sharing.
PS a shorter sidestand bumper will keep it from dragging.
