moto fugazzi Posted October 17, 2014 Posted October 17, 2014 I guess what I was trying to say is that I was going to use disconnect the reference wire, and use the black wire (on the charge light side once disconnected) to go to #86 of the relay, and connect #87 to the black reference wire (on the regulator side). I already have a no load power wire from the battery (fused) that would connect to #30 of the relay. It's from the headlight relay that used to be in the headlight bucket that was removed a while ago. Make sense? I'm assuming the the black wire you call the reference wire is attached to the same SAE connector as the white wire. 1
Kiwi_Roy Posted October 17, 2014 Posted October 17, 2014 Yes, I think you have it right I sent you a PM
docc Posted October 17, 2014 Author Posted October 17, 2014 I like this plan! My Sport needs another relay on top the four I've added. (I just do it to make Hubert nervous ) If, per chance, the red-black reference wire in the loom shows no significant voltage drop then this more direct reference system would unnecessary, correct? (My voltage drop is 0.09 V)
Kiwi_Roy Posted October 17, 2014 Posted October 17, 2014 Voltage drop only 0.09 V Then I'm guessing you have a pair of headlight relays powered directly from the battery, either that or your headlights turned OFF Are you happy with your battery Voltage?
docc Posted October 17, 2014 Author Posted October 17, 2014 Right, headlamps on a separate circuit through a 10 amp circuit breaker with separate OMRON relays, hi and low, and grounded back to the frame. It charges at >14V as low as 2000 rpm. I still don't trust the system to run a 77 watt electric jacket under 4000 rpm . . .
chamberlin Posted October 19, 2014 Posted October 19, 2014 Might we make a basic bullet point instructional for this beefing up of the regulator/charging systems? I have a stock wiring system, and my bike came with an Odyssey, so I am now concerned about frying something. I'll go ahead and beef up the grounds as suggested, but I think it would be neat to have a definitive 'checklist' and step by step mod plan for everyone. I often encounter a weak battery, and I regularly trickle the Odyssey on a CETEK higher end charger. So the Rectifier Regulator is actually drawing current with the bike switched off? Although not likely, the RR might be damaged by charging if you don't isolate the battery first? Could a high current battery disconnect switch (kill switch) be engaged when the bike is sitting for long periods or when charging? Could we come up with a definitive reference voltage mod for the RR? 1
luhbo Posted October 19, 2014 Posted October 19, 2014 ... It charges at >14V as low as 2000 rpm. ... This is not how it officially should be. Running the system with extra relais and grounds usually brings the regulator voltage down below 14V, to something around 13.8. In case you have a stabilised or switched power supply unit at hand or in your neighbourhood go and check your volt meter. Those modern cheap ones may not be the most precise ones, especially once the internal 1.5V are fading. Hubert
docc Posted October 19, 2014 Author Posted October 19, 2014 This is true, of course, yet the DE I installed is claimed to set for 14.2 volts. I will have my Triplett meter checked (Good advice, as always! ). I replaced it's internal 9v, but the voltage reading did not change. (My very cheap meter that I carry with me in the Tekno pannier reads 0.12 volts less - maybe it is the more accurate . . . )
docc Posted October 24, 2014 Author Posted October 24, 2014 The specialty electronics store I bought the meter did not have a stabilized power supply and figured sending it to a repair facility would cost about what I paid for the meter (50 USD). It's stated accuracy for DC voltage is +/- 0.8% which is 0.11 volts at 14.2 vDC. So, assuming my meter has retained its stated accuracy, my charging voltage could be as low as 14.09. I think it is notable, though, that the regulator is set to 14.2 volts and the meter reads the same (at or above 2000 rpm).
LaGrasta Posted 4 hours ago Posted 4 hours ago It's been some time since I've visited the forum. Frankly, I needed time for my moral to recover after too many attempts to repair my V11 charging problem. After replacing the battery, rectifier, and stator, it still doesn't charge above 13.4. Is there a special rectifier if I'm using a lithium battery?
gstallons Posted 3 hours ago Posted 3 hours ago I don't THINK it would matter. This 13.4v , what RPM are you running the bike at ? Give us charging V at ilde , 1500 and 2500 . Also , do you have a temp gun you can shoot the connection of the two yellow wires coming out and going to the regulator ?
LaGrasta Posted 3 hours ago Posted 3 hours ago I've tested the bike at numerous rpm, always charging about 13.4 regardless.
gstallons Posted 3 hours ago Posted 3 hours ago And the connection ? If it is easy to disconnect , unplug it and hook your DVOM _(on AC scale) up to the two wires coming out of the engine and start it up . You should get around 25v AC with it running . Shut it off and reconnect.
gstallons Posted 3 hours ago Posted 3 hours ago At rest , what does your battery voltage show , engine off ? 1
gstallons Posted 2 hours ago Posted 2 hours ago Looking at the service manual : you should show 15v @ 1,000rpm . 40v @ 3,000 rpm and 80v @ 6,000 . I would not be stupid enough to tach it up to 6,000 in N so just stick w/the first two test #s. These are just for reference so don't condemn everything if it is w/in 20% of the V output of the test chart. 1
