docc
prior to touching the head fixing nuts, check the following:
the oil feeding connection on the inner side of the head - remove the fuel tank to get there
the plug in the head that allows access to the inner stud - just remove the valve cover. There is an o-ring underneath the 10 mm allen plug
When the head bolts are not loosened, the o-rings underneath the rocker arm brackets never get leaky.
  • 4 years later...
So, I was given the proper O-rings to perform this task. They are simply under a plug beneath the valve cover, no need to disturb the rocker assembly or the head bolts..
I absolutely could not get that 10mm hex-drive plug loose. Out came the Gedore 500 kg machinist's hammer and the impact tool. No budge. I quit before tearing it up.
Perhaps with the tank off, I could apply heat and try again . . .
I mean, they're just plugs, right? Should not have high torque or thread locker?
Not as far as I know.. but you never know who's been in there on an old bike.
Hey! I resemble that remark! :oldgit:
On mine, that was the o-rings under the inside cyl. stud nut cover, the big allen plug.
Mine were tight enough that I used a 1/2-3/8 adapter and a 24" 1/2 breaker bar. (because that's the one that was at hand)
All components Snap-On, and the Allen key was inspected for a good tip. It came right off then with no drama.
I big ratchet with a vacuum cleaner tube makes a nice breaker bar.  At least it works when I drain the water heater on my travel trailer.
