cash1000 Posted December 8, 2014 Posted December 8, 2014 Try Ghezzi Brian. I asked them in July this year and they had a Carbon Fibre one for sales 220e incl freight to NZ
luhbo Posted December 8, 2014 Posted December 8, 2014 On 12/7/2014 at 11:48 PM, LowRyter said: Harley pegs? Yes. But to get the most out of them you should alter the levers, too. Hubert
ferguzzi Posted December 8, 2014 Posted December 8, 2014 Talked to Bruno. €235 for me in the Emerald Isle, due VAT. Still a good deal I think. How difficult is it to paint carbon fibre?
Scud Posted December 8, 2014 Posted December 8, 2014 On 12/8/2014 at 10:43 AM, ferguzzi said: Talked to Bruno. €235 for me in the Emerald Isle, due VAT. Still a good deal I think. How difficult is it to paint carbon fibre? I think he has a plastic one too. Maybe a bit cheaper than CF - and better for paint. He had quite a lot of other stuff for V11s and said he's going to start a new section of his website just for parts. He called them "tuning parts." That must be a nearly-accurate Italian to English translation. When I think "tuning" I think of getting the engine to run right. I think a better English word might be "custom parts."
Scud Posted December 10, 2014 Posted December 10, 2014 I got a package from Italy today. It appears that the chin spoiler will bolt right on with the supplied hardware, but I will need to drill holes in the rear fender to mount it with the supplied bracket. The weave of the carbon fiber material is a bit finer than the stock Scura parts, but they look really good - and they weigh nothing. Should be able to install this weekend.
Scud Posted December 12, 2014 Posted December 12, 2014 Chin spoiler went on easily. Four L-shaped brackets using the four corner bolts of the oil pan - each of which takes a rubber compression fitting with a built-in rubber washer for the inside of the spoiler. I think I will get some little rubber washers for the outside - just to minimize the stress around the screw holes.
Scud Posted December 12, 2014 Posted December 12, 2014 On 12/12/2014 at 6:53 AM, luhbo said: Scud, does the fender cover the shock eye? I didn't install the rear fender yet. To do so, I will need to remove the rear bolt for the shock in order to install the bracket. Unlike the chin spoiler, the holes are not pre-drilled in the fender - but all the screws and washers are included. The CF fender is a lot smaller than the stock piece, but it seems like it will still offer pretty good protection from spray. I'll post a picture in a few days.
Scud Posted December 14, 2014 Posted December 14, 2014 On 12/12/2014 at 6:53 AM, luhbo said: Scud, does the fender cover the shock eye? I failed at installation today, because I only have a stand that lifts the swingarm. I have not figured out how to raise the bike in a way that will release the pressure on the shock so I can remove and reinstall the bolt easily. However, I took a couple photos to show how the bracket and fender will be positioned. They will protect the shock-eye from tire spray. The stock fender left it wide open to spray - probably even channeled extra spray onto it. This makes a lovely retrospective rationalization for my purchase...
luhbo Posted December 14, 2014 Posted December 14, 2014 Thanks for the pictures, Scud. The idea how to install the bracket is a nice one. Hubert
Scud Posted December 20, 2014 Posted December 20, 2014 I installed the rear fender and put some more info about it in a new thread. http://www.v11lemans.com/forums/index.php?showtopic=18833
Scud Posted January 6, 2015 Posted January 6, 2015 Update on living with the chin-spoiler: It was buzzing at about 3,000 RPM. I isolated the buzz by sticking a little piece of split vacuum line in various suspect spots. Once I identified the source (right in front of the side-stand bracket) I sanded the edge down so it was far enough away from the bracket. No more buzzing. It's not particularly fond of getting sprayed with rocks. I bought a clear plastic strip that is intended to protect the kick-plates in car door frames. Trimmed to fit the the bottom - I can barely see it - should have put it on before going mudding the other day. There is still no functional reason to put a chin spoiler on a V11. I still like it very much and would do it again.
LowRyter Posted January 6, 2015 Posted January 6, 2015 I agree that belly pans have no real purpose. But they look cool and make your bike different from everyone else's. I had to do it to my Bandit.
docc Posted January 7, 2015 Posted January 7, 2015 I think it gives the Bandit a fine "stance!" Especially with the painted frame color. Bandits, otherwise, have always looked top-heavy to my eye. V11? I suppose they look heavy all over; like a husky chick on high heels: lotsa fun, but ya best be careful!
