Hi, I've had my fairing and side panels dipped to look like carbon fibre , water transfer printing, the results are stunning, looking to get my front m/guard done next! what you guys think!
Looks great, I had a Rosso Mandello that had the tail piece, hugger, front mudguard, side panels and fairing done, bit over the top for me, I kept the hugger when I sold it and it's on my Nero now, only downside it's not very durable and damages easily but looks the dogs.
Looking good.  That transfer printing is getting better all the time.  A pieces of CF look cool - but as Steve said, it's possible to go too far with it. I like the look of the CF front fender on my Scura.
Cool thing about wraps - if you don't like them, you can always peel them off.  Try it and see.
The fairing looks good! Whoever did it looks to be experienced - it's easy to distort the patterns on the odd contours.
Will you apply a clear coat to harden the surface?
I had my tail section covered with this and I AM VERY SATISFIED ...
  • 3 months later...
anybody knows of where to do this in the USA, let me know.  My carbon fiber pieces are pretty sun stained, looking grey - like my beard.
Seems like emery cloth would make a smoother surface for coating without the chance of getting small metal strands under any stray carbon fibers.
What sort of clear coat would be best, acrylic?
Good call on the metal strands Docc, yes- sand it with just enough grit/force to remove the old clear coat. Clean and prep the piece very thoroughly, and then use this stuff:  http://www.eastwood.com/eastwood-s-2k-aerospray-high-gloss-clear.html
or
http://www.eastwood.com/spray-max-2k-high-gloss-clearcoat-aerosol.html
The previous owner to my Aprilia did this on the front carbon fiber fender, and aside from some very minor bubbles (preventable by good sanding and prep), the thing looks factory fresh.
p.s. here is a really good read if you've got the time:
http://ephedyn.blogspot.com/2010/04/comprehensive-guide-to-clear-coat.html
Those plastic scotchbrite pads are also good for prep before paint. They actually come in different "grits".
