Scud Posted February 9, 2015 Posted February 9, 2015 Looks promising. Is the unit backlighted? Looks like a "button" and three indicator lights (what do they do?) BTW, Scud - your voltages are on the marginal side. Look at conditioning your AGM (12.5v is 75%) and make efforts to get your charging voltage above 13.8, ideally 14.2. More stuff to learn? Ok, I did not expect such a thorough eduction when I got this bike (and joined this forum). The wire is connected directly to the battery. I ran it behind the headlight where I can also plug in the charger or USB adapter; it has a 7.5 fuse. I think the Battery Tender product is only intended to test batteries at rest - in fact, they don't even call it a meter, they call it a "Voltage Indicator." The button just wakes it up for about 10 seconds, then it displays the voltage digitally (not backlit) and lights up Green for charged (>12.0v), Yellow for low (11.6v to 12.0v), and Red for discharged ( I just tested it again and payed closer attention to the numbers Bike at rest without key: 12.6 Bike off, but key on: 12.1 Running at 4,000 RPM: 13.7 FYI - high beams were on for key on and running tests. Also used multi-meter for two tests (would need another set of hands to test while running) Key off: 12.62 Key on: 12.20 (high beams still on) While they call this product a voltage indicator, it seems to also be a fairly accurate meter. The battery is new as of three months ago when I got the bike (dealer installed). It's a Yuasa with these numbers: 12V 13Ah (10HR) VRLA YTX15L-BS (M6215L) I saw something on another thread about battery conditioning, which I have never done before. I also don't know how to increase charging voltage. How is that done? And if you don't mind, could you explain why 14.2 volts charging is important?
Kiwi_Roy Posted February 9, 2015 Posted February 9, 2015 It's not important to reach 14.2, your 13.7 is good enough and probably easier on the battery. I can tell you how to increase the charge Voltage but need to know more about your existing wiring. Headlamp size? Do you have headlight relays? OEM regulator? Sent you a PM Roy 1
docc Posted February 9, 2015 Posted February 9, 2015 Play off Kiwi_Roy's post and go with his expert recommendations. I suggested the 14.2 based on the Hawker Odyssey specifications for the PC545 AGM that needs re-charged from below 90% (12.65v). Specs on your Yuasa may vary.
