The factory stand is well and good. I don't have one and probably half of you don't either, so what are you using?
It's not clear in any photo I've seen, where the stand latches on. I guess under the rear subframe just inside the bottom of the porkchops?
I have a cunning plan ( I could be related to Baldrick too ), but before I embarrass myself and drop it, what works to get the rear off the ground and level?
The factory stand captures the two nuts on the very bottom attachment of the porkchops that through-bolts under the back of the gearbox.
  On 2/13/2015 at 2:07 PM, Craig said:
I like my factory stand.  It pays for itself very quickly.
A volunteer! Please measure the height of the lower porkchop bolt off the floor when stand up. Also, how high is the rear tyre off the ground?
I just picked up a swing arm stand at Harbor Freight, with the 20% off coupon it was $25.  I did have to "manipulate" the stand a bit to fit the swing arm but it works just fine.
With the preload cranked up on my Ohlins, I have to put a 4x4 block under the factory stand handle to get the rear tire to clear the floor about an inch.
I might be lucky to buy a pair of suitable wheels for $25 here. My cunning plan involves scraps of timber, minimally high enough to get the rear wheel in the air in the resting position.
Thanks, I hadn't forgotten about variations in suspensions, sitting on the ground, how high is your porkchop bolt?
The nuts are off the deck about 10 1/2 inches with the front up about an inch in the Sport Chock.
:nopic:
11" (30cm) from floor to center of bolt.  1.75-2 (4.4-5cm) inches below the rear tire.
Rough Maths
( Stand Height @ porkchop - porkchop height - front chock lift ) /=/ ( rear droop + rear wheel clearance)
Assumes stand is roughly in the middle.
Thanks, I'll assume you have stock suspension.
