crazyhorse Posted February 27, 2015 Posted February 27, 2015 I would like to replace the black instrumentholder in my Rosso Corsa by an carbon one. Will this fit? The carbon holder was mounted with Veglia clocks. Do they have a different size or diameter? Did anyone do this replacement before? Thanks, Henk
Steve S Posted February 27, 2015 Posted February 27, 2015 I just did the same, I have been restoring an 02 bike that came to me with a carbon fibre bracket and I have swapped it onto my Nero Corsa which had a plain black one, no problem straight swap.
gstallons Posted February 27, 2015 Posted February 27, 2015 I don't know why it would not work . The one onmy bike has 85 mm openings on the tach / speedometer holes .
crazyhorse Posted February 27, 2015 Author Posted February 27, 2015 Thanks for the replies. I just wanted to be sure before I buy one.
GuzziMoto Posted February 27, 2015 Posted February 27, 2015 Funny thing. Ducati tend to use ALMOST exactly the same part between models, they change it just slightly. Guzzi tend to use EXACTLY the same part between models, only changing it if they have to. The cases on my Guzzi's still have the boss cast into it where the distributor went.
