dangerous Posted May 11, 2015 Posted May 11, 2015 all right, them farking Iti's designed a engine were to replace the slave cyl for the clutch... ya gota remove the swing arm... hows it done guys? wheels out I see the lower shock bolt and them big bastards on the pork chops... now what?
Steve S Posted May 11, 2015 Posted May 11, 2015 That's it really, take out the rear torque arm bolt and slide the bevel box off, remove the rear shock bolt, while it's off grease the front UJ, when refitting the pivot pins get them even each side, tighten them finger tight up to the bearings so there's no side play in the swingarm
dangerous Posted May 11, 2015 Author Posted May 11, 2015 pivit pins? when the big nuts on the pork chop are undun what happens then, is there a axle to push throu or is this these pivit pins you mention?
Steve S Posted May 11, 2015 Posted May 11, 2015 Loosen the big nuts then wind out the pivot pins with an allen key then the swingarm will fall out
docc Posted May 12, 2015 Posted May 12, 2015 Measure, first, how much the threaded portion of the pivots stand proud of the pork chops. They are probably not symmetrical. Otherwise, you'll have to center the rear tire to the front on re-assembly. Plan on servicing the swingarm bearings while it is out.
The Monkey Posted May 12, 2015 Posted May 12, 2015 and those bearings will not come out easy Heat and press, the assembly team lives in N Italy. The disassembly team left the country in '44 1
dangerous Posted May 12, 2015 Author Posted May 12, 2015 LOL @ the monkey ahh so its not a axle or shaft bit a big arse pin one in each side yeah? shit giza bloody exploded view some one :-)
dangerous Posted May 12, 2015 Author Posted May 12, 2015 bloody hell... is that it, thanks man will look into this weekend ta
dangerous Posted May 12, 2015 Author Posted May 12, 2015 ummmm... the bikes on the race stand, how do you guys suport it when removing the arm?
Kiwi_Roy Posted May 12, 2015 Posted May 12, 2015 Jack under the sump, carve out a stick of 4 x 2 to fit snug the sump and header pipes.
docc Posted May 12, 2015 Posted May 12, 2015 On 5/12/2015 at 11:00 AM, Kiwi_Roy said: Jack under the sump, carve out a stick of 4 x 2 to fit snug the sump and header pipes. I added a chain fall (ratchet strap) to the rear tank mount for extra measure.
dangerous Posted June 21, 2015 Author Posted June 21, 2015 well that was a piece a piss, cant believe them wee pivot bolts is all that holds it togeather... and the last time I disconected a rear shock was my CX500 turbo and it was under load the V11 was as free as. new thread here http://www.v11lemans.com/forums/index.php?showtopic=19101&hl= now as there is a new issue... of course "sigh"
gstallons Posted June 21, 2015 Posted June 21, 2015 When you replace the swingarm bearings , remove the dust shield of one side of the bearing and fill it completely w/wheel bearing grease . Put the dust shield back on and install this side in away from the outside of the bike. .Roller bearings come w/just enough grease to not rust. This bearing is not going to roll but pivot a few degrees throughout it's lifetime so grease is going to make it last from now on. When you are ready to install the pivot pins grind a bevel or taper on them so they will go through and into the bore of the bearing easily. If you crossthread these pins , just remove the swingarm and screws them from the inside out to clean up the threads . Good luck & keep us posted !
Kiwi_Roy Posted June 23, 2015 Posted June 23, 2015 Good tip, threading the pivot pins in from the inside. My old uncle, a plumber taught me to start large threads by turning slowly backwards until you feel them click off the end of thread then go forward because the threads are lined up. Sent from my shoe phone! 2
