Delman Posted June 23, 2015 Share Posted June 23, 2015 Hi all. like to rig my signals to flash as 4 way hazard lights as well ran across this searching youtube https://youtu.be/b11rD3n-d7s too easy to be true it seems like, you fox with electrical knowledge, is the above a choice? any other way? i haven't looked in to it in depth yet and would apriciate some guidance, thanks Delman Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted June 26, 2015 Share Posted June 26, 2015 Just try adding a switch between Left & Right side, Of course you will need to turn the blinkers on also, You could add a dedicated flasher powered from the battery with a pair of diodes left & right, powering the flasher would feed each side through a diode. The flasher would be selected with 4 lamps in mind. Sent from my shoe phone! Link to comment Share on other sites More sharing options...
