reading through the forum, I was reminded about MPH Cycles in Houston and how they helped me on a cross the USA trip many years ago.  I asked them for a speedometer transmission (part no. 01 76 25 60) for my 2002 Scura, see no.5 in attachment.  MPH said after checking with MG, the part is discontinued (ie, not available) and said I would have to ebay for it.
Can a guy rebuild it?  I understand the part is only used in V11 Sport models.
Any advice would be helpful.
Cheers,
James
  • 2 weeks later...
Gunther, thanks for that link.  Looks like they have the part in stock so I will try to order.  All the best.
Craig, the speedo is erratic and sometimes doesn't work at all.  The gears are probably not setting any longer on the mechanism No. 5 in the drawing.
Thanks guys.
Cheers.
  • 3 weeks later...
parts arrived from http://www.stein-dinse.biz  talked with them a couple of times in english to ensure the right part was being sent.  parts arrived, installed yesterday, and every thing is back to normal.  Thanks Gunther!.  Case is closed.
jt
moved to Ashland Oregon from St. Augustine, FL
