sp838 Posted October 4, 2015 Posted October 4, 2015 Sorry if this has been asked before, but an idea popped into my head and I was wondering if anyone knew the answer off hand: would the rear hub from a California V11 of the same vintage be compatible with the rear drives on our V11 LeMans? (don't have it handy right now but I'm gonna look this up in Guzziology, might be some clues there.)
gstallons Posted October 5, 2015 Posted October 5, 2015 I can think of no reason it would not. It would be dumb not to use the same components on all models . Maybe different gear ratios IDK ? Is this what you are after ?
sp838 Posted October 5, 2015 Author Posted October 5, 2015 For a while I had a fantasy of running spoked alloy wheels. Now I fantasize about running Marvic wheels, but after having this idea, I thought I'd at least research it. Looking at the part numbers didn't make me overly optimistic though, as many of the cush drive part numbers appear to be different, for starters. Wheel bearings are the same though... Inconclusive at this point. http://www.harpermoto.com/parts-by-motorcycle/2000-up-moto-guzzi-motorcycles/california-ev-pi-cat-1100-2003-2005/rear-wheel-en-ev-pi-cat-1100-2003-2005.html http://www.harpermoto.com/parts-by-motorcycle/2000-up-moto-guzzi-motorcycles/v-11-cafe-ballabio-1100-2003-2005/rear-wheel-en-v11-cafe-ballabio-1100-2003-2005.html
Kiwi_Roy Posted October 5, 2015 Posted October 5, 2015 The V11s have an open shaft, the California is in the swing arm, I don't know if that makes a difference. The wheels on my 98 EV are nice tubeless spoked. 1
sp838 Posted October 5, 2015 Author Posted October 5, 2015 Very interesting, 98 EV actually shares some common parts... I wonder how the widths of the hubs compare.
Kiwi_Roy Posted October 5, 2015 Posted October 5, 2015 If I get a chance I will measure them up, they are sitting side by each in my garage.
danl Posted October 6, 2015 Posted October 6, 2015 There is an old thread on this: http://www.v11lemans.com/forums/index.php?showtopic=17114&hl=%2Bspoked+%2Bwheels I always thought this sounded like a cool idea, although the stock wheel is already a pain to clean behind those discs! 1
fotoguzzi Posted October 7, 2015 Posted October 7, 2015 I'll bet the Cali rims weight quite a bit more than the stock mags..
sp838 Posted October 7, 2015 Author Posted October 7, 2015 If I was to do it, I would lace them up to some excel rims. Our stock rear wheel is a boat anchor.
GuzziMoto Posted October 8, 2015 Posted October 8, 2015 I'll bet the Cali rims weight quite a bit more than the stock mags.. The stock V11 wheels are pretty heavy as well. I would not be surprised if you were able to build some spoke wheels that were as light or lighter than the stock V11 wheels.
docc Posted October 8, 2015 Posted October 8, 2015 I'll bet the Cali rims weight quite a bit more than the stock mags.. The stock V11 wheels are pretty heavy as well. I would not be surprised if you were able to build some spoke wheels that were as light or lighter than the stock V11 wheels. Tubes add back a lot of weight, don't they?
GuzziMoto Posted October 9, 2015 Posted October 9, 2015 I'll bet the Cali rims weight quite a bit more than the stock mags.. The stock V11 wheels are pretty heavy as well. I would not be surprised if you were able to build some spoke wheels that were as light or lighter than the stock V11 wheels. Tubes add back a lot of weight, don't they? It is easy enough to convert a spoke wheel to tubeless. SuperMoto guys do it all the time. There are cheap ways to do it and expensive ways. A typical tube does not weigh that much, but it does add weight. The bigger reason to convert for something like a Guzzi is that flat tires aren't as sudden and repairing on the roadside is easier. Tubes tend to loose air very suddenly in the event of a flat, and repairing a flat cannot be done using a quick plug when you have a tube. So, you can run spoke wheels without running a tube. The cheap way to convert involves duct tape and silicone. As scary as that may sound, it is done fairly often.
