activpop Posted August 5, 2023 Posted August 5, 2023 I had two folks wig out on me, so two pair still available. But you're in Germany. If I knew earlier, I could have brought some with me. I'm in Sweden now, just a tad closer. 1 1
audiomick Posted August 5, 2023 Posted August 5, 2023 6 hours ago, activpop said: ... two pair still available.... I may just get back to you on that. Depends on how I get on here... When are you back at home?
audiomick Posted August 5, 2023 Posted August 5, 2023 I found this just now: https://www.kardanwelle24.de/kardanwellenkomponenten/kreuzgelenke-kreuzgarnituren/kreuzgelenk-kreuzgarnitur-fuer-quad-und-andere-anwendungen-22-x-50-2-mm/a-3339 Looks like the right size, and "Zentralschmierung" should mean it has a central grease nipple. Hmmm.... I also have a tip for a place that re-conditions drive shafts. That would include balancing.
4corsa Posted August 5, 2023 Posted August 5, 2023 Day 1 of 3 day 600+ mile tour in the Catskill MountainsSent from my SM-S901U using Tapatalk 8
activpop Posted August 5, 2023 Posted August 5, 2023 7 hours ago, audiomick said: I may just get back to you on that. Depends on how I get on here... When are you back at home? 8/12 1
fotoguzzi Posted August 5, 2023 Posted August 5, 2023 Not a V11 but today I rode my Ambo around a few blocks, fresh from a 6 year nap. 7
audiomick Posted August 5, 2023 Posted August 5, 2023 Very nice photo. If you would care to oblige, I'd be interested in knowing focal length, f-stop, exposure time and ISO. Getting back to motorcycles, after 6 years you pulled a more than 50 year old motorcycle out of the shed, kicked it in the guts, and rode it around the block? Go on, tell us the full story. I'm curious for one...
docc Posted August 5, 2023 Posted August 5, 2023 11 minutes ago, audiomick said: Getting back to motorcycles, after 6 years you pulled a more than 50 year old motorcycle out of the shed, kicked it in the guts, and rode it around the block? Go on, tell us the full story. I'm curious for one... Drop. Dead. Gorgeous. 3
audiomick Posted August 5, 2023 Posted August 5, 2023 Thanks docc. I had seen that, but forgotten. And yes, gorgeous.
fotoguzzi Posted August 5, 2023 Posted August 5, 2023 30 minutes ago, audiomick said: Very nice photo. If you would care to oblige, I'd be interested in knowing focal length, f-stop, exposure time and ISO. Getting back to motorcycles, after 6 years you pulled a more than 50 year old motorcycle out of the shed, kicked it in the guts, and rode it around the block? Go on, tell us the full story. I'm curious for one... sure, Canon 6D EF100-400, ISO 250, 340mm, f5.6, 1/320s 16 mp 5045x3257 4.9MB. THE STORY IS. All the restoration creds go to my friend John U.. stripped to the bone and rebuilt with a lot of new parts (Gilardoni kit of course) in 2003.. He’s clearing out the Guzzi stuff and keeping 2 Corvettes. I bought it earlier this year but was busy and too hot to work on it till now. Pretty much all I did was put the tank back on and connected with some new gas and battery she struggled for a moment then fired up. Carbs were clean but not in sync and I got stuck figuring out a stuck choke which took longer than it should have but last time I owned a bike with carbs was my first Convert around the late 90’s. Since then only FI , a V11 Lemans, Bassa, Uly, and Hyperstrada. The Buell and Ducati were monstrously fast. I’m in the slow lane now with drum brakes etc.. Sunday rider.. when I want torq or speed I take my Tesla. Then the dogs can come too. 5 1
audiomick Posted August 6, 2023 Posted August 6, 2023 8 hours ago, fotoguzzi said: ... 340mm... Yeah, thought it must have been fairly long. Thanks. Looks like your mate John did a very good job.
4corsa Posted August 6, 2023 Posted August 6, 2023 Day 1 of 3 day 600+ mile tour in the Catskill MountainsSent from my SM-S901U using TapatalkRoadside repairs, so much funSent from my SM-S901U using Tapatalk 2
4corsa Posted August 6, 2023 Posted August 6, 2023 Roadside repairs, so much funSent from my SM-S901U using TapatalkTemp fix done. Battery charging again. It was the stator connection that friedSent from my SM-S901U using Tapatalk 3 1 1
audiomick Posted August 6, 2023 Posted August 6, 2023 Today I took the front end off to have a look at the steering head bearings. Not that there were any signs of trouble, but I wanted to see how much grease was in there. Turns out adding a bit more wasn't such a bad idea. Bright idea of the day (or week, or month...) obvious really, to hold it in place whilst putting it back together. But I was a bit chuffed that I thought of it in the heat of the moment and all by myself, and how well it worked. I poked around and looked at a couple of other things as well. All part of getting to know the bike, and being able to contemplate longer trips without worrying too much if the wheels are about to fall off. 5
docc Posted August 6, 2023 Posted August 6, 2023 4 hours ago, 4corsa said: Temp fix done. Battery charging again. It was the stator connection that fried Sent from my SM-S901U using Tapatalk I don't recognize that connector as original to the V11 stator (?) An electrical failure like that can be hell on downstream components (regulator and relays). Be aware of/ monitor for sequelae . . . [edit: it also occurs to me to check the attachment of the two yellow wires to the stator under the alternator cover for breakage. Probably not "on the road", but when home.] 2 1
