FJFOOL Posted January 21, 2016 Share Posted January 21, 2016 I would like to ad an oil pressure guage to my '07 Norge, has anyone added one, or know a good location on the engine to tap into ? Thanks ! Link to comment Share on other sites More sharing options...
Kostarika Posted January 21, 2016 Share Posted January 21, 2016 You can take a look at page 4 here. Scud hooked one up to his LeMans. http://www.v11lemans.com/forums/index.php?showtopic=19038&page=4 If you want to go the mechanical way you can get a double banjo and tap into the double oil line that oils the heads. The only guy in the US that has it is here (The banjo bolt that is) http://www.thumperstuff.com/SRXTTT.html#engine Hope that helps. Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted January 21, 2016 Share Posted January 21, 2016 Not the only guy, that's how I did it on my Eldorado. The nice part about putting it on the faring, you can use copper tube since it doesn't have to flex. Another good spot is the steering damper bracket or crash bar Sent from my shoe phone! Link to comment Share on other sites More sharing options...
FJFOOL Posted January 22, 2016 Author Share Posted January 22, 2016 I definitely want to go mechanical so I will order the banjo bolt from Thumpers. Thanks for the link, Kostarika ! Roy, I hadn't considered copper tube, good idea ! Thanks for the reply, guys ! Link to comment Share on other sites More sharing options...
