cda Posted March 17, 2016 Author Posted March 17, 2016 Thanks I'll have that in mind! So far other things have kept me busy. But soon, hopefully, I get started with this little project.....
cda Posted May 30, 2016 Author Posted May 30, 2016 Problem solved, thanks a lot for all good advices, but it ended up in just simple bad connection. This was previously "repaired" by someone and once I got the tank and all the electrical tape off a yellow cable. The annoying and confusing issue was out of the world. It has probably started with a damaged cable to close to the ten pin connector to fix. The happy repairman thus pulled both the female and male pins out of the connector, put them together and then used a lot of tape to hold them together. Still without proper connection though.........As a result of the bad connection there was a significant fall in voltage and not enough power to light the bulbs properly on high beam and the still working tail light. Perhaps it's not the right conclusion in electrical terms but its working with significantly brighter gauge light and parking light anyway thanks a lot.
