2004 Ballabio. The plastic around the temp sensor has broken off, and there is nothing for the socket to grip.  At this point it looks like I may have to remove the head in order to remove it.  The only thing to get a hold of is a round metal thing sticking up in the hole. I'm open to suggestions here.  :luigi:
I had the same problem, ended up using this, came right out.....remember to soak in PB Blaster first:
...and a third way is to use a screw extractor. It winds into the hole in the metal remains of the sensor housing, and you can unscrew it easily.
I fitted a brass temp sensor housing instead of the plastic one. MG part no. 30163301.
