czakky Posted March 20, 2016 Posted March 20, 2016 I'm waiting on parts and getting prepped to finally change out my upper sump ring/flange so that my kickstand is working properly. Anyway a few months ago I bought a used upper sump ring/flange. Today I was stripping off some of the hardware in preparation and found the finish bubbling off the oil cooler line coupler/nipple things. The part with the sealing washer. Finish is really coming off. Obviously I'm not using the part but what could have caused this? Should I be worried?
czakky Posted March 21, 2016 Author Posted March 21, 2016 The yellow "chromate" is flaking off. Just wondering if there is a 14yr life in the chromate Guzzi used or do I need to find what kind of oil this guy used.
Scud Posted March 21, 2016 Posted March 21, 2016 Let me see if I understand this: You have some used oil line fittings that came with the used sump ring - but they are flaking You also have good oil lines and fittings on your bike, which you plan on using If that's correct, then where is your concern? Is it that something may be wrong with the upper sump ring? Can you see any damage to sump ring? Or perhaps you are just curious?
victor Posted March 21, 2016 Posted March 21, 2016 The yellow "chromate" is zinc passivation. And maybe motor oil is a little bit acid which over the years have "eaten" the zinc.
czakky Posted March 21, 2016 Author Posted March 21, 2016 Yeah, Scud just curious. I'm not using the coupler on the new ring. The couplers were still covered in oil, kind of unnerving thinking that oil might be breaking this zinc/chromate whatchamacallit down.
czakky Posted April 28, 2016 Author Posted April 28, 2016 I just pulled these couplers/nipples from my bike. The zinc chromate coating is definitely failing on mine too. Is this a worry?.... What other parts have this coating that are in contact with oil?
