Colorobo Posted July 18, 2016 Posted July 18, 2016 Where do I get the key or tool for the front axel? on a 2004 Le mans
Scud Posted July 19, 2016 Posted July 19, 2016 My 2003 LeMans doesn't require a special tool - just a big wrench and some hex drivers. What are you concerned about? Can you post a picture of whatever has you puzzled?
moto fugazzi Posted July 19, 2016 Posted July 19, 2016 Never saw a key for one of these. I remove the axle nut, loosen the pinch bolts and tap the axle a little with a rubber mallet. Then it pulls right out. Ken
Colorobo Posted July 31, 2016 Author Posted July 31, 2016 What are the torque spec for the reinstall on the axel bolt. thanks
fotoguzzi Posted August 1, 2016 Posted August 1, 2016 I just used a channel lock pliers to loosen that nut and replace it w/a hex nut.
