knumbnutz Posted August 8, 2016 Posted August 8, 2016 Hey everyone, Does anyone have the exact size of the Universal joint ? In the U-Joint Store they list to uni joints for Guzzi - http://theujointstore.com/moto-guzzi.html but not what bike they fit. Measuring the OD of the bearing is 22mm on Uni i have out Measuring the distance across the bearing is 51.7mm Can't seem to find much info on ebay or any of the main guzzi shop websites, but i am just after a replacement rather than an entire shaft and uni's. regards Neil
Angelo.M Posted August 9, 2016 Posted August 9, 2016 Hey everyone, Does anyone have the exact size of the Universal joint ? In the U-Joint Store they list to uni joints for Guzzi - http://theujointstore.com/moto-guzzi.html but not what bike they fit. Measuring the OD of the bearing is 22mm on Uni i have out Measuring the distance across the bearing is 51.7mm Can't seem to find much info on ebay or any of the main guzzi shop websites, but i am just after a replacement rather than an entire shaft and uni's. regards Neil Have a look at their B1 catalogue.http://www.hardyspicer.com.au/driveline_products.asp Cheers Angelo
footgoose Posted August 9, 2016 Posted August 9, 2016 no idea knumb, but following this to see what you find.
knumbnutz Posted August 9, 2016 Author Posted August 9, 2016 http://www.hardyspicer.com.au/PDF_Files/Driveline/B1_Catalogue_2014-15lr.pdf page 33 I'll have to take the bearing there to check. Also the local Guzzi dealer said he gets the bearing from another place close by http://www.driveline.com.au/contact-us and have plenty of options in the catalogue So I'll check the two places out.
