MartyNZ Posted May 31, 2018 Posted May 31, 2018 OK, who was the member that switched out the long shift lever pivot bolt with one with a longer un-threaded section? I can't find one anywhere. The problem with the stock bolt is the threaded section goes too deep into the carrier (on the inner end). The threaded area is a smaller diameter than the collar. Not by much, but causes it to rattle a bit at that spot. I remember someone mentioning it and forgot to follow up. I figure as long as we're focusing on shift improvement, why not?I wrote a comment about that back in post 27 of this topic, along with adding a grease nipple.I got a bolt that was too long, cut it to length, then threaded it the minimum amount needed. 1
Chuck Posted May 31, 2018 Author Posted May 31, 2018 Wow. Just checked paypal, and all but one have already paid. (!) Gotta love Guzzi guys..
footgoose Posted May 31, 2018 Posted May 31, 2018 OK, who was the member that switched out the long shift lever pivot bolt with one with a longer un-threaded section? I can't find one anywhere. The problem with the stock bolt is the threaded section goes too deep into the carrier (on the inner end). The threaded area is a smaller diameter than the collar. Not by much, but causes it to rattle a bit at that spot. I remember someone mentioning it and forgot to follow up. I figure as long as we're focusing on shift improvement, why not?I wrote a comment about that back in post 27 of this topic, along with adding a grease nipple.I got a bolt that was too long, cut it to length, then threaded it the minimum amount needed. Yes Marty, that is the post I saw. I remember thinking mine rattles there a bit too. I'll keep looking for one, but that long of an unthreaded section And a socket head is rare. Nipple's are always a good idea too. Thank's for catching me up. 1
Stumble_t Posted May 31, 2018 Posted May 31, 2018 Thanks so much for knocking this out Chuck! Now my shifter improvement project will be complete. This will match nicely with my best ever, super deluxe, properly engineered, belts and suspenders shift return spring. I presume you are also performing LuckyPhil's "Shift Improvement" modifications? Yes, thats the plan. I have a new selector that I've straightened and dressed in preparation as well as all new springs, the McMaster bearing upgrade, replacement seals, and other goodies I've discovered while scouring all the valuable info here. Not that shifting has been terrible, but while I'm in there doing preventative maintenance replacing the selector return spring, why not. 1
Chuck Posted June 6, 2018 Author Posted June 6, 2018 Aaaaarg.. I just received this: My package arrived this morning, but to my surprise there are two. Could you tell me who the second one is for so I can forward it on. Uh oh. That means someone paid for 2 and got one. For whatever reason, I had Rob down for 2. Who did I short change?? I'll get into this in the morning. We're having a dinner party tomorrow night, and I have to make a rib rub, and get the ribs prepped tonight.
Tomchri Posted June 7, 2018 Posted June 7, 2018 Chuck. Dont know the collar of the pills the mailman are using,,,, but I was Lucky recieving the 2 I ordered today,, was that 8days only. Overnight sounds like a Wonder. Ok another homemade IPA. Thanks Chuck Cheers tom. 1
Mike S Posted September 9, 2018 Posted September 9, 2018 Ah, late to the party and missed the order. Put me down for the next batch plse! Unless you have spare on the shelf... Cheers Mike
O2 V11 Posted September 10, 2018 Posted September 10, 2018 Mike S, No need to wait, I have one on hand. I have sent you a PM Rob
Chuck Posted September 10, 2018 Author Posted September 10, 2018 Mike S, No need to wait, I have one on hand. I have sent you a PM Rob Yay.. I was going to mention that the OEM's shipping department screwed up and sent Rob an extra..
O2 V11 Posted September 12, 2018 Posted September 12, 2018 I have a spare no more, off on it's way, courtesy of NZ Post to MikeS in sunny Australia. Rob
Mike S Posted September 12, 2018 Posted September 12, 2018 Thanks chaps - now I'll just need to fit it some reading to do before it arrives...
mjseymo Posted September 27, 2018 Posted September 27, 2018 Can you put me down on the list for one too£ when are they next available I'm in the UK. Thanks Martin
al_roethlisberger Posted November 1, 2018 Posted November 1, 2018 Are any of these still available after the latest batch? Seems I missed the last round before that, and I'd like to get one. Thanks Al
Chuck Posted November 1, 2018 Author Posted November 1, 2018 Al, Martin, Dave.. I have recently upgraded the cnc and computer, and will use up my available blanks to make some for you. Send your mailing address to: 59dot Chuck at gmail dot com. 1
al_roethlisberger Posted November 1, 2018 Posted November 1, 2018 Al, Martin, Dave.. I have recently upgraded the cnc and computer, and will use up my available blanks to make some for you. Send your mailing address to: 59dot Chuck at gmail dot com. Thanks, mailing address sent in email!
