Lucky Phil Posted August 6, 2020 Posted August 6, 2020 On 8/4/2020 at 10:12 PM, Chuck said: The market *may* be saturated. When I first made them, I thought maybe 10 would want them, but it sort of snowballed. I've made a bunch of them since then. I put a "factory reject" on the Mighty Scura to finish the last order, so I'm tapped out. The easiest thing for you to do is simply weld an extension on your OEM lever. I think that's what Lucky Phil originally did. Yep thats it Chuck Ciao
Vic Posted August 6, 2020 Posted August 6, 2020 Gstallon, I like your idea of bolting on the extension, like you said this way you can go back if it doesn't work right,thanks for you input. 1
Chuck Posted August 6, 2020 Author Posted August 6, 2020 5 hours ago, Vic said: Gstallon, I like your idea of bolting on the extension, like you said this way you can go back if it doesn't work right,thanks for you input. That is why I put the original hole in the extender. I haven't "heard" of anyone going back, though.
Chuck Posted August 7, 2020 Author Posted August 7, 2020 Quote Vic said: "Also since Chuck no longer is making the "lucky Phill" shift extension arms, this might be another possibility. " Oh, I'll make them, but the water jet shop won't do less than 10. It's not worth their (or my) time to make the blanks. 3 1
Kane Posted August 7, 2020 Posted August 7, 2020 3 hours ago, Chuck said: Oh, I'll make them, but the water jet shop won't do less than 10. It's not worth their (or my) time to make the blanks. Chuck, I’m in for another run if there’s enough demand and you’re so inclined. 1
Tom in Virginia Posted August 7, 2020 Posted August 7, 2020 22 minutes ago, Chuck said: Find nine others, and you are number one. I'm game for two shift extension arms, one for each of the V11's. 3 down, seven to go! 1
Vic Posted August 8, 2020 Posted August 8, 2020 Thanks for your interest in a second batch, I definitely want one!
docc Posted August 8, 2020 Posted August 8, 2020 14 hours ago, Vic said: Thanks for your interest in a second batch, I definitely want one! Third batch, yah? First gen: zinc chromate finish, second gen: black powder coat, third gen: ?? "Collect them all! " 2
footgoose Posted August 8, 2020 Posted August 8, 2020 1 hour ago, Vic said: Red might be nice. 1 hour ago, docc said: Third batch, yah? First gen: zinc chromate finish, second gen: black powder coat, third gen: ?? "Collect them all! " (Chuck) ----- ,... ,... 1 2
