luhbo Posted June 21, 2017 Posted June 21, 2017 The RM is 2°Series, they came without these parts. I don't know the early 'crown' versions of '99/2000, maybe they needed them. Don't bother, you would have noticed that something's missing. The manifold's also different to that pictured here.
Tinus89 Posted June 21, 2017 Author Posted June 21, 2017 If it's not, you have nothing to seal the gasket.. I'm not sure I understand where these parts actually go? My exhaust has a flat face, which I think should seal against the gasket. The RM is 2°Series, they came without these parts. I don't know the early 'crown' versions of '99/2000, maybe they needed them. Don't bother, you would have noticed that something's missing. The manifold's also different to that pictured here. I have the second series (not the crown, but the oval flange), but I think the drawing intends the use of those flanges for both...
GuzziMoto Posted June 23, 2017 Posted June 23, 2017 The parts circled in red allow the ring that bolts to the head to push on the pipe just shy of the head. The rings that bolt to the head are large enough to slip over the end of the pipe, so without something else there is no way they could push the end of the pipe into the exhaust port on the head. So, the two circular parts fill the gap between the ring and the pipe, allowing the ring to push the end of the pipe into the exhaust port on the head. I do not know if all V11s have those parts, but if your ring can come off the end of the pipe as ours can they have to have something.
Tinus89 Posted June 28, 2017 Author Posted June 28, 2017 Sooo, I replaced both gaskets. Came out quite easily. The right one had a minor leak, see the pic: The metallic rattle is still there... Any other ideas?
luhbo Posted June 28, 2017 Posted June 28, 2017 Not over the internet. What if you check TLM for this? You're far away from his shop?
Tinus89 Posted June 28, 2017 Author Posted June 28, 2017 Not over the internet. What if you check TLM for this? You're far away from his shop? I am indeed quite far away from them, but I did check with them last year (with the bike there). After listening, they gave me a list to check when I disassembled the engine. Which I did, and found nothing. I don't really feel like going there again....
Chuck Posted June 29, 2017 Posted June 29, 2017 Earplugs. Guzzis make many noises that aren't fatal. Pete says the only fatal one is the "Dogga dogga" noise.
Tinus89 Posted July 5, 2017 Author Posted July 5, 2017 At this point, I'd say run it till it blows. Earplugs. Guzzis make many noises that aren't fatal. Pete says the only fatal one is the "Dogga dogga" noise. I think I have made my decision indeed, to leave it for now and see if it develops for something worse, and then fix the collateral damage Thanks for the help all!
luhbo Posted July 5, 2017 Posted July 5, 2017 Probably a good decision. The summer is short. Just watch out for changes.
motoguzznix Posted July 13, 2017 Posted July 13, 2017 Since the sump is already dismounted, you could further dismount the oil filter assembly (just 4 screws) and then drop the rod big end screws to inspect the plain bearings. Reassembling is no problem as the screws must not be replaced, Just to be sure about that.... Torque is around 65 Nm if I remember that well. My next step would be to inspect the cam shaft axial bearing as Phil an others mentioned. Whith the Stucchi tensioner you can unscrew that small 8 mm nut and remove the tensioner with the chain and wheels in place. At this stage check also the crankshaft axial play. The front bearing can be changed from the front without further disassembling (just remove the chain sprocket) in case of wear. If after all that the noise is still present, I would dismount the heads to check valves and guides for wear. This is very common on the V11 engines and the only weak point. As I pointed out on my much earlier post above. wear of the valve guides is not uncommon on a V11. Compared to the work done up to now, this is a minor issue...
Tinus89 Posted July 13, 2017 Author Posted July 13, 2017 Since the sump is already dismounted, you could further dismount the oil filter assembly (just 4 screws) and then drop the rod big end screws to inspect the plain bearings. Reassembling is no problem as the screws must not be replaced, Just to be sure about that.... Torque is around 65 Nm if I remember that well. My next step would be to inspect the cam shaft axial bearing as Phil an others mentioned. Whith the Stucchi tensioner you can unscrew that small 8 mm nut and remove the tensioner with the chain and wheels in place. At this stage check also the crankshaft axial play. The front bearing can be changed from the front without further disassembling (just remove the chain sprocket) in case of wear. If after all that the noise is still present, I would dismount the heads to check valves and guides for wear. This is very common on the V11 engines and the only weak point. As I pointed out on my much earlier post above. wear of the valve guides is not uncommon on a V11. Compared to the work done up to now, this is a minor issue... I would agree, but: - Would I not see significant oil consumption over the valve stems? - Could this cause a metallic rattle?
Chuck Posted July 13, 2017 Posted July 13, 2017 You'll see a puff of blue smoke on startup with worn valve stems, but not much consumption, really. Metallic rattle? I wouldn't think so.
luhbo Posted July 13, 2017 Posted July 13, 2017 And even then there's still the question whether they must be changed or not. I opened my engine at 125.000km because the valve train then was really noisy at higher revs - that is around 8000 rpm. So what ...
motoguzznix Posted July 18, 2017 Posted July 18, 2017 If valve stems and guides are worn out severely you will hear some metallic rattle.
