What are the vent lines sizes under the tank? I am thinking or cutting them and Quick connects. Also the crossover to the throttle body has a t in it and went to the vapor canister that is gone. Bike is 2004 Le mans. can I Remove the t and just connect them? thanks This forum is a huge help with issues. Rob Pancake
Sizes: Who knows? Pull 'em off and take them into a parts store or your local dealer.
Hose between throttle bodies: if the vapor canister is gone, you can simply put vaccum caps on the ports. You do not need to run a line between the throttle bodies.
Vent and overflow under the tank push onto a pair pf nipples; kind of already a "quick disconnect." There just a little fiddly to get to reaching in from the front of the tank once it's lifted a little.
