Walterg Posted September 30, 2016 Share Posted September 30, 2016 When I got to work this morning I discovered the righthand valvecover gasket was leaking. At the moment there is enough oil in the pan but I'm not sure if I should ride it home for repairs. It's about 23 km (14 miles). What do you think ? Link to comment Share on other sites More sharing options...
gstallons Posted September 30, 2016 Share Posted September 30, 2016 Check the oil level and ride it home . Your boot & maybe your pant leg will be soaked . When you get home , remove the valve cover and you might find the wrong gasket on the valve cover . Silicone gaskets are available or if you can't wait , use a gasket eliminator . Link to comment Share on other sites More sharing options...
Walterg Posted September 30, 2016 Author Share Posted September 30, 2016 Thanks for your prompt reply gstallons. I cleaned everything this morning and I will check the oil later today. If the level is somewhere above mid-dipstick I'll carefully ride it home. I intend to replace the gasket with a new one. Link to comment Share on other sites More sharing options...
Kiwi_Roy Posted September 30, 2016 Share Posted September 30, 2016 Jamb some paper towel in around the plug, it will absorb most of the oil coming out, a teaspoon full goes a long way. Link to comment Share on other sites More sharing options...
Walterg Posted September 30, 2016 Author Share Posted September 30, 2016 I'll do that Kiwi_Roy. Now on my way to home.... Link to comment Share on other sites More sharing options...
JesterGrin_1 Posted September 30, 2016 Share Posted September 30, 2016 Nobody mentioned this as it may simply be a given but have you checked the valve cover hold down bolts as they simply might be loose. Link to comment Share on other sites More sharing options...
docc Posted September 30, 2016 Share Posted September 30, 2016 Hopefully, Walterg is home now . . . On the South'n Spine Raid, the 1200 Sport start dripping from the left valve cover. In my (dubious) wisdom, I cinched it down but actually just pushed the gasket inside the valve cover. The only motor I've seen leak oil like that had a hole in the oil pan. We were really impressed just how much oil a big block Guzzi pumps up onto the rockers! Several of us ought to swing by Walterg's and give him a hand! Link to comment Share on other sites More sharing options...
Walterg Posted October 1, 2016 Author Share Posted October 1, 2016 Hey I made it home without any issues ! Of course the right side of the bike and my boot were completely covered in oil when I got home but ther was still enough oil in the pan. I probably could use a helping hand fixing the gaskets so I'll go down and get some more beer. 1 Link to comment Share on other sites More sharing options...
gstallons Posted October 1, 2016 Share Posted October 1, 2016 Yep.... Link to comment Share on other sites More sharing options...
