Have you found all the answers to K Roys questions ?    He knows,,,, you will find it.
Cheers tom.
True that, on following Kiwi_Roy's advice. :thumbsup:
gatorman, If I am reading correctly, you are trying to use a starter for a California on a V11?  Certainly, the flywheels are different. Enough different that those starter are incompatible? IDK. Anyone with this experience?
Cheers tom.
i still have not found an answer
i used the id number and that starter is what came up if i am using the wrong starter please point the way to find the right starter
13 hours ago, gatorman said:
just tried a test put model clay on the flywheel and installed the starter  the teeth on the starter were bigger than the teeth on the flywheel meaning that the starter gear is to big?
Original starter on a 2001 V11 would be Valeo, not Bosch.
From the parts "fiche" ---> Starter motor Valeo  GU30730711
Check with r3datom9 currently parting out a 2000 Sport in CA, USA. That would be the correct starter for your 2001:
https://www.v11lemans.com/forums/index.php?/topic/20736-2000-sport-part-out/
Here is the V11 replacement starter that Tinus89 found in The Netherlands for 60Euro:
https://www.winparts.nl/motordelen-toebehoren/startmotoren-dynamo-s/startmotor/c834/startmotor-moto-guzzi-1-2-kw/p582790.html
"Aantal tanden" = 9 (tooth count)
The starter you are using has 8 teeth?
Check with r3datom9 parting out a 2000 Sport. That would be the correct starter for your 2001:
Also, take a look at Gordon's comments on MGCycle for the replacement starter and the "Alternate Starter":
http://www.mgcycle.com/index.php?main_page=product_info&cPath=37_159&products_id=1227
Posted (edited)
Thanks for weighing in Docc, I have no experience with swapping starters.
Sorry it was me that mentioned Bosch, Gatorman said D6RA2
It sounds as though Gatorman has the bikes original starter as well though, that should fit
I still don't know for sure he is talking about a VII or something else, we don't have the obligatory picture, LOL
So it turns out to be a VII Bassa at least that's what it says on the side cover, beautuful mile muncher, the EVs had foot boards, I prefer the pegs and love those tubeless wheels, a classic Guzzi for sure.
Edited by Kiwi_Roy
I see the picture
gatorman   i do not have the original starter. it came with the d6ra2. so the person i got the bike from changed the original starter and installed the d6ra2 and never rode the bike again because the d6ra2 is not the right starter for the bike and would not start
7 hours ago, guzzigary said:
Looking at the gallery post methinks gatorman has a California not a V11.   :not:
Haha . . . well there is that! :blush:
ok i bought a starter for the cal. and it did not work . now what ?    when i did a vin decoder  it says i have a v11 bass cruiser model year 2001 with the califorina trim. so what model starter do i get???   vin number zgukdbd31m131679  gatorman
7 minutes ago, gatorman said:
Gatorman   hope the picture posts in my gallery
Yeah, man. Looks like a nice pearl white V11 EV?
All my comments were applicable to a 2001 V11 Sport or Rosso Mandello. The EV has a different (5 speed) gearbox and different flywheel from the V11 Sport, so none of my replies are likely going to be helpful.
Or would the starter I linked you to on MGCycle solve your troubles?
