fotoguzzi Posted April 13, 2019 Posted April 13, 2019 To me it looks like a Bassa not EV. Or in later years (2001?) known as a special sport.. late to the party but what's all the discussion over what starter fits? Both the Tonti and V11 big twins use the same Valeo starter. 1
fotoguzzi Posted April 13, 2019 Posted April 13, 2019 38 minutes ago, docc said: Or would the starter I linked you to on MGCycle solve your troubles? Yes the starter from MGcycle will fit any v11 or Tonti frame big twin. 1 1
gatorman Posted April 15, 2019 Posted April 15, 2019 well i finally got the starter problem fixed this bike was sitting for about 5 years. with starter installed the bendix did not completely extend. bought the starter you guys cam up with works perfect put some clean gas in it with a little coaxing if fired right up. now have to check all the fluids and get ready for a ride . thanks to all gatorman 1
Kiwi_Roy Posted April 16, 2019 Posted April 16, 2019 On 4/12/2019 at 6:45 PM, fotoguzzi said: Yes the starter from MGcycle will fit any v11 or Tonti frame big twin. Be sure to give us a ride report, I'm sure you will be surprised what the old girl can do.
Kiwi_Roy Posted April 17, 2019 Posted April 17, 2019 On 10/2/2016 at 5:20 PM, czakky said: When voltage decreases amperage increases. Right? I'd say job well done! Guys often get the transformer rule mixed up with Ohms law. If you drop the Voltage through a transformer the current goes up as the Voltage goes down, it 's really not applicable to your bike.
