belfastguzzi Posted February 2, 2004 Share Posted February 2, 2004 OK , I'll bite. Whats the ' rest of the story?' Ok, recap: so, ZX 6R with 20,000 miles run the engine at 8,000 rpm for 30 minutes to sort of warm it up pipes glow... red hot coolant boils and overflows - all of it radiator fan switches off as no coolant to heat the switch continue to run engine at high revs for another half hour no apparent problems - could wear be increasing, oil burning or carbonising -- seized bearings or pistons???? the manual says 3,5 litres capacity is all that oil really needed? Drain oil, boiling oil melts plastic tank as explained before. Part 2: put in ONE litre of oil (funny, they don't seem to debate what sort would be best) oil boils immediately, but carry on anyway start engine, tape throttle fully open. Shortly there's a bit of a hiccup as backfires start. The rev limiter is cutting the spark so that petrol is exploding in the exhaust. Big flames, small holes appear, big holes appear, big noise, fire extinguishers appear. Leave the building, coughing. Conclusion of story: Come back next day when things have cooled put in oil start the engine it runs smoothly Hooray. The bike won. Go on - try it for yourself. Link to comment Share on other sites More sharing options...
