LowRyter Posted November 1, 2016 Posted November 1, 2016 This just happened this morning. When I turn on the right signal: no indicator on dash, right front flashes, and both rears (LED) flash. When I turn on the left signal: dash indicator works, left front does not work, left rear (LED) flashes so far: I switched the left and right front bulbs. cleaned and inspected fuses; cleaned relays; sprayed cleaner in the switch. The rear turn signals are Badlands LED. There is a box under the saddle to compensate for resistance. I have a call into Badlands to determine if or what to replace as there is no part number on the box. Any help and advice appreciated.
MartyNZ Posted November 1, 2016 Posted November 1, 2016 Indicators can do odd things if you have a bad connection to ground on one indicator. It will then find a ground through another lamp in the circuit. I'd be looking for one of the indicators negative connection loose, corroded or broken.
LowRyter Posted November 1, 2016 Author Posted November 1, 2016 Thanks Marty....I'll check. Also: I don't see the OEM Flasher. Am I right to assume the Badlands box replaces it?
LowRyter Posted November 1, 2016 Author Posted November 1, 2016 Marty, right on. Found that turn signals were separately wired and came apart at the connectors. I am not sure why, since only the rear are LEDs and this one was OEM. Anyway, one of the wires came loose at the connectors. And of course both turn signal wires came loose before I got them reconnected and matched the four different colored wires. Not a lot of room to crimp and tape them. 1
bbolesaz Posted September 11, 2017 Posted September 11, 2017 Thread resurrection, slightly different subject. Where is the flasher unit physically on the bike. I cannot find it.
coreytrevor Posted September 11, 2017 Posted September 11, 2017 Mine is right in front of the relays, but it's zip-tied to the frame so it may be moved slightly from original.
bbolesaz Posted September 11, 2017 Posted September 11, 2017 Thanks coreytrevor. I'll check tonight. Maybe I need better glasses. I know it's there, because the TS flashes, just not reliably.
coreytrevor Posted September 11, 2017 Posted September 11, 2017 You might be able to hear it if it's not an electronic one.
Chuck Posted September 11, 2017 Posted September 11, 2017 Here, you can see it. About 4 inches in front of the relay block, on the outside of the tube. I'd say it's a factory installation. 2017-09-11_02-54-01 by Charles Stottlemyer, on Flickr
bbolesaz Posted September 12, 2017 Posted September 12, 2017 Found it, thanks mucho ! Is there a generic replacement, or do I gotta call Harpers?
coreytrevor Posted September 12, 2017 Posted September 12, 2017 It should be a 2-prong flasher relay. The bulbs are 10w each so any generic one that's spec'd for that wattage should work. Or if you get one of the ones for use with LEDs, it doesn't matter how many watts the bulbs are. But the advantage of the ones made to work with a certain wattage is that if a bulb goes out they will usually either not flash or flash really fast, so you know a bulb is out. The LED types won't do that.
mznyc Posted October 4, 2017 Posted October 4, 2017 Found it, thanks mucho ! Is there a generic replacement, or do I gotta call Harpers? Yes,mine died a few years ago and got one at a local NAPA store....Couple bucks.Just bring yours in and they should have a replacement.
mznyc Posted October 4, 2017 Posted October 4, 2017 Here, you can see it. About 4 inches in front of the relay block, on the outside of the tube. I'd say it's a factory installation. 2017-09-11_02-54-01 by Charles Stottlemyer, on Flickr Chuck what is that damp spot by the relays?....
Chuck Posted October 4, 2017 Posted October 4, 2017 Oh, I imagine it's over spray from DeOxit when I put the new Omrons in.
