Hi Gents,
Probably for the Australian guys mainly but I just got my Uni's replaced - fitted, reshimmed from Driveline Services Australia for $168 which I thought I would pass on if anyone needed them done.
Seems like a good price replacement and fitment.
One was very grinding from a lack of maintenance, so while apart I did both
Sent from my D6503 using Tapatalk
Did you have to remove it to feel this?
Yes, But being what it is , is pretty easy to do once the wheel is off.
The bike had been left outside although under cover for a long time, all the rubber had perished, the gearbox and bevel drive had stinky sludge for oil, so it wasnt unexpected.
At 80K you would check this anyhow I guess.
With the uni's in hand, it clicked as i moved the joint through its arc. For the sake of $160, it wasnt worth regreasing and seeing if they'd be ok.
Was it the nefarious, elusive front that went bad?
