docc Posted November 30, 2016 Posted November 30, 2016 +1 on both the lift and finding a better way to park the front wheel. I roll my Sport into a Baxley Trailer SportChock. If I'm wrangling it around much, I'll tie it down with ratchet straps. The factory shop stand doesn't roll well on the diamond plate, so I use a suitably sized polyethylene cutting board under it. Once on the stand, the sump can be jacked to remove the front wheel (or entire front end for that matter).
droydx Posted December 1, 2016 Posted December 1, 2016 Good idea about using a poly cutting board to use the factory stand! Thanks docc! 1
swooshdave Posted April 20, 2017 Posted April 20, 2017 It helps to have a cute redhead with a truck help deliver the lift. The wife, on the other hand, was not amused. Based on the wisdom over on ADV the first thing I did was toss the wheel clamp and bolted on the HF wheel chock. It's adjustable so it securely fits a wide variety of bikes. With the chock you can roll the bike on by yourself and it will stand securely. You can then attached the tiedowns for added security at your leisure. I too was one of those people who couldn't understand how I went so long without a proper lift. Previously I had a homemade stand, which worked pretty good but I was limited by how big of a bike I could roll up the ramp to it. 200lb Bultaco? Not a problem, 400lb Norton, not as fun. http://www.harborfreight.com/1800-lb-capacity-motorcycle-standwheel-chock-61670.html At around $60 give or take (be sure to use coupons!) it's a huge relief to have the bike held very securely.
docc Posted April 20, 2017 Posted April 20, 2017 Should you posting something yellow in the "Cars . . . " thread?
swooshdave Posted April 20, 2017 Posted April 20, 2017 Should you posting something yellow in the "Cars . . . " thread? No one here cares about old cars...
docc Posted April 20, 2017 Posted April 20, 2017 Should you posting something yellow in the "Cars . . . " thread? No one here cares about old cars... Oh, you must go to the "Cars . . ." thread. Otherwise, you could start your own "Identify This Car By Only the Front Corner" thread . . .
swooshdave Posted April 20, 2017 Posted April 20, 2017 Oh, you must go to the "Cars . . ." thread. Otherwise, you could start your own "Identify This Car By Only the Front Corner" thread . . . Fine, just to make you happy.
docc Posted April 20, 2017 Posted April 20, 2017 This business of sneaking in Bultacos is highly circumspect on the other hand.
swooshdave Posted April 20, 2017 Posted April 20, 2017 This business of sneaking in Bultacos is highly circumspect on the other hand. I hate that when that happens. 1
Chuck Posted April 20, 2017 Posted April 20, 2017 Back in the day, I had many happy miles on the back of a Bull.. Don't go dissin Bultacos..
Chuck Posted April 21, 2017 Posted April 21, 2017 Bultaco, Montesa, Ossa? All them is real sickles. Gas-gas? Late comer..
docc Posted April 21, 2017 Posted April 21, 2017 Bultaco, Montesa, Ossa? All them is real sickles. Gas-gas? Late comer.. Haha - true that! Like me, I guess . . .
swooshdave Posted April 21, 2017 Posted April 21, 2017 I still need to figure out how to change the front tire. I can borrow one of the side lifts which should get it off the ground just enough.
footgoose Posted April 21, 2017 Posted April 21, 2017 I still need to figure out how to change the front tire. I can borrow one of the side lifts which should get it off the ground just enough. you could do as Chuck mentioned and back the bike in. Nice Norton btw. I owned a 75 for several years. Sweet sound. Garage art.
