Any 5 pin will work in all locations. From memory (roll eye) number 1 *needs* to be a 5 pin.
Is there one part # that can be installed in all positions ?
Chuck is correct. Only Position #1 *needs* to be 5-pin. Best one to use across the board: G8HE-1C7T-R-DC12
http://www.digikey.com/product-detail/en/omron-electronics-inc-emc-div/G8HE-1C7T-R-DC12/Z5645-ND/2755412
What part # for the # 1 position ?
 You can use the listed high current G8HE-1C7T-R-DC-12 in all the positions
The #1 position must have the "C" in the number (5-pin/ SPDT).
Wow, extensive research, love it, and thank you Docc. Just ordered some. And now the GEI relays I bought to upgrade the ones that came on the bike are no longer needed  :homer:  :homer:  :homer:
Hey, you can *probably* use those GEI for an auxiliary lighting circuit without issue. And carry for spares. :huh2: (I have 5 GEI in the monkey-paw trap along with a couple Bosch and a few OMRON).
Should this go on the compatible parts page?
It should. It really should . . . :blush:
