LowRyter Posted September 4, 2023 Posted September 4, 2023 29 minutes ago, docc said: What position did the damaged OMRON come out of? That could be an indication of a connection issue on that circuit causing voltage spikes. Most especially, damage to the yellow output wires at the stator can destroy the regulator and relays. I have no idea. It was originally the starter I believe. Is that that front #1?...I moved so many around that I can't be sure.
docc Posted September 4, 2023 Author Posted September 4, 2023 8 minutes ago, LowRyter said: I have no idea. It was originally the starter I believe. Is that that front #1?...I moved so many around that I can't be sure. Yes, front is Start. 1
Bingbong Posted February 4, 2024 Posted February 4, 2024 I just found these on eBay.de made in USA. They have the extra T-R1 from the old Omron part number. Will they work? Says they are high current.. G8HE-1C7T-R1 5PIN DC12V relay
audiomick Posted February 4, 2024 Posted February 4, 2024 Do you mean this ad by any chance? https://www.ebay.de/itm/176128295514?hash=item290210825a:g:OdAAAOSwNIZkF8rp&amdata=enc%3AAQAIAAAA8AwZlpW%2BYazOq6a%2F2TLrAwQglkMgom7EGX1QHsI1sznZygK3JkpPJqmdiOPNsX2DNbvCPwTyVCJ2zZhq6Ci5pE4IPXXe1ChEQTGPwwGJ67cPD1pSFGGicroYWKqgvHl%2BtyUC%2FTrQZZ4wdmUwNU%2FlI6qlcWrBVVOO2P2xSL0L%2B8QSVx%2F4POMcuyOghMP8CEk0Cdqy%2BbPBfdUe7riYbSQgFmFrFWJgFTIcUBCE18RBAckR0umge8gE0nCXQBml%2F56R3AgdSzElH4wm6G%2BJu%2FFEeq2MCGSCXDlm0r%2FZWifoOTGLSH%2FS8iZsEGr3LDpWtBO3kg%3D%3D|tkp%3ABk9SR-LFwceuYw It says "Made in USA" on the relay in the pictures, but the listed location of the goods (Standort) is Shenzhen, China. Nevertheless, I dare say they would work.
docc Posted February 4, 2024 Author Posted February 4, 2024 3 hours ago, Bingbong said: I just found these on eBay.de made in USA. They have the extra T-R1 from the old Omron part number. Will they work? Says they are high current.. G8HE-1C7T-R1 5PIN DC12V relay 29 minutes ago, audiomick said: Do you mean this ad by any chance? https://www.ebay.de/itm/176128295514?hash=item290210825a:g:OdAAAOSwNIZkF8rp&amdata=enc%3AAQAIAAAA8AwZlpW%2BYazOq6a%2F2TLrAwQglkMgom7EGX1QHsI1sznZygK3JkpPJqmdiOPNsX2DNbvCPwTyVCJ2zZhq6Ci5pE4IPXXe1ChEQTGPwwGJ67cPD1pSFGGicroYWKqgvHl%2BtyUC%2FTrQZZ4wdmUwNU%2FlI6qlcWrBVVOO2P2xSL0L%2B8QSVx%2F4POMcuyOghMP8CEk0Cdqy%2BbPBfdUe7riYbSQgFmFrFWJgFTIcUBCE18RBAckR0umge8gE0nCXQBml%2F56R3AgdSzElH4wm6G%2BJu%2FFEeq2MCGSCXDlm0r%2FZWifoOTGLSH%2FS8iZsEGr3LDpWtBO3kg%3D%3D|tkp%3ABk9SR-LFwceuYw It says "Made in USA" on the relay in the pictures, but the listed location of the goods (Standort) is Shenzhen, China. Nevertheless, I dare say they would work. Another member sourced the High Current OMRON G8HE from China via eBay and found them to be legit. While OMRON no longer produces them, it is not unlikely that some resourceful Chinese company bought up the NOS from other suppliers and has marked them up. Not sure what the US dollar price is on US eBay, but ~22 Euro for four is not bad (depending on the shipping). Of course, the price doubles if you want to buy five, because of their packaging quantity . . . 3
LowRyter Posted February 4, 2024 Posted February 4, 2024 My first failed relay on my two Guzzis was a replacement Omron. Luckily I have plenty, starting with the OEMs. The ones taken from the Greenie were Bosch. Now one of those has been returned to service. 1
docc Posted February 4, 2024 Author Posted February 4, 2024 2 minutes ago, LowRyter said: My first failed relay on my two Guzzis was a replacement Omron. Luckily I have plenty, starting with the OEMs. The ones taken from the Greenie were Bosch. Now one of those has been returned to service. Those Bosch were decent relays. PyroDan sold them for a short time before going with the Chinese GEI. Yet, even the Bosch are under-rated for Position 5 (fuel/Ignition) and, on the early V11 wiring (1999-2001), Position 1 (especially the "5th pin"/NC contact). Failure of a High Current relay can be an indication of voltage spikes from a faulty regulator or/and the nefarious detachment of the yellow charging wires at the stator. 2
80CX100 Posted February 4, 2024 Posted February 4, 2024 22 minutes ago, docc said: Failure of a High Current relay can be an indication of voltage spikes from a faulty regulator or/and the nefarious detachment of the yellow charging wires at the stator. I've started adding dedicated grounds to my R/Rs to hopefully eliminate potential issues. I've never had a relay go bad,,,but definitely stop working because it wasn't seated into the socket correctly. If I can see the relays, I always confirm good contact & push them into place before the seat goes back on. fwiw ymmv 1
LowRyter Posted February 4, 2024 Posted February 4, 2024 1 hour ago, docc said: Those Bosch were decent relays. PyroDan sold them for a short time before going with the Chinese GEI. Yet, even the Bosch are under-rated for Position 5 (fuel/Ignition) and, on the early V11 wiring (1999-2001), Position 1 (especially the "5th pin"/NC contact). Failure of a High Current relay can be an indication of voltage spikes from a faulty regulator or/and the nefarious detachment of the yellow charging wires at the stator. I have replaced regulators on both Guzzis and at least one stator. 1
Bingbong Posted February 4, 2024 Posted February 4, 2024 2 hours ago, docc said: Another member sourced the High Current OMRON G8HE from China via eBay and found them to be legit. While OMRON no longer produces them, it is not unlikely that some resourceful Chinese company bought up the NOS from other suppliers and has marked them up. Not sure what the US dollar price is on US eBay, but ~22 Euro for four is not bad (depending on the shipping). Of course, the price doubles if you want to buy five, because of their packaging quantity . . . Thanks! they had 3 packs of 4 available. So bought them all . Delivery will be a while they say. Chinese new year next week... 1
V11_RM_RG Posted December 17, 2024 Posted December 17, 2024 Found this on RS Components: https://nz.rs-online.com/web/p/automotive-relays/9156641?srsltid=AfmBOoqDfRIxASaK-LYNHYx_oe-z_NAF360P7fVi5Aw0776KOuLA9a7m Spec/ Data sheet looks impressive. I did some research on Durakool, it's a UK based companies and owned by Solid State PLC, which is a company that supplying electronics components to commercial, industrial and military markets. Has anyone use this particular relay before? 1
docc Posted December 17, 2024 Author Posted December 17, 2024 2 hours ago, V11_RM_RG said: Found this on RS Components: https://nz.rs-online.com/web/p/automotive-relays/9156641?srsltid=AfmBOoqDfRIxASaK-LYNHYx_oe-z_NAF360P7fVi5Aw0776KOuLA9a7m Spec/ Data sheet looks impressive. I did some research on Durakool, it's a UK based companies and owned by Solid State PLC, which is a company that supplying electronics components to commercial, industrial and military markets. Has anyone use this particular relay before? Thanks, @V11_RM_RG! That data sheet is, indeed, impressive! Silver alloy contacts rated for continuous current of 40 amps on the normally open contact and 30 amps on the normally closed with a strong 1.8 watt coil on the resistor-equipped 5-pin relay. I did not find this relay in the US at either Digikey or OnLineComponenets, but others have been more successful at this. Anyone see a US or Europe supplier?
gstallons Posted December 18, 2024 Posted December 18, 2024 Just Google the Durakool DG82-2011-36-1012-DR and you will get plenty .
docc Posted December 18, 2024 Author Posted December 18, 2024 51 minutes ago, gstallons said: Just Google the Durakool DG82-2011-36-1012-DR and you will get plenty . So, are these relays available in the USA? Everything in my web search says "UK" and "back ordered" . . . I see this United Arab Emirates site with the exchange rate about $4 per relay, but no idea about the shipping/extra costs . . . https://ae.rsdelivers.com/product/durakool/dg82-2011-36-1012-dr/durakool-plug-in-automotive-relay-12v-dc-coil-40a/9156641 1
docc Posted December 22, 2024 Author Posted December 22, 2024 On 12/17/2024 at 6:36 PM, docc said: So, are these relays available in the USA? Everything in my web search says "UK" and "back ordered" . . . I see this United Arab Emirates site with the exchange rate about $4 per relay, but no idea about the shipping/extra costs . . . https://ae.rsdelivers.com/product/durakool/dg82-2011-36-1012-dr/durakool-plug-in-automotive-relay-12v-dc-coil-40a/9156641 I was watching for @Speedfrog to perform his unique locator talents on this one . . . 1 1
