andy york Posted February 24, 2017 Author Posted February 24, 2017 and #2 and i also don't know why the site turns everything 90* anyway there is a shim first (on reassembly) then the bearing assembly then the castled nut ...of which the seal goes inside and the 0-ring goes in the groove on the OD of the castle nut then the spacer and finally the 36 mm nut I fit the seal to the inside of the castle nut and the o-ring into the groove. generously coating each with a film of grease. then install the castle nut. then lube the spacer up and gently push it home.... it has to go through the seal....so be careful. then install the 36 mm nut and torque to 180 -200 Nm
