dangerous Posted March 18, 2017 Posted March 18, 2017 Once again thanks to V11 owner Marty he has assembled this extension for the air censor that used to plug into the airbox.Photos explain all really, ECU is now happy its reading a censor again. Marty did design it to bolt down to the old air box mount as pictured but I was concerned its right in line of the rear wheel splatter, so went up behind the battery, anywere under the tank would trape heat Ideally if it was 100mm longer behind the side of the tail piece or in the case of a LeMans forward of the fairing. 2
MartyNZ Posted March 18, 2017 Posted March 18, 2017 Hopefully now that Nero Corsa will run just as sweetly on frosty mornings as it will on hot afternoons. It looks like you found a good place to put the sensor. The cable does come with a satisfaction guarantee, so I can add 100mm to it if you think it needs to be longer. A little tie-wrap over the plug should stop it coming undone. I think I put one in that bag of bits with the cable.
docc Posted March 18, 2017 Posted March 18, 2017 Well done, guys! And just in time for the inaugural Akaroa Spine Raid . . . Wait, what you guys did probably is the Akaroa Spine Raid! 1
dangerous Posted March 18, 2017 Author Posted March 18, 2017 Hey thanks heaps Marty, BTW the plug connected very easy and on 2nd try... again I owe ya, hopefully tomorrow Ill be able to give it a road test. docc... WTF are you dribbling about LOL do you mean the Akaroa GP (best done early or during the week) ahhh what did we do?
docc Posted March 18, 2017 Posted March 18, 2017 I keep dribbling on that Spine Raids ought to pop up everywhere. Get Spineys together - have your way with them! 1
dangerous Posted March 19, 2017 Author Posted March 19, 2017 well I did kinda raided the pub over the hill... was the only spine there tho any hooo... I didnt think there was much of a diference with the air temp disconected, but with the new extension shit, started beter, and smoother bit more peaky, could be in my head but im sure its happier with it conected... cheers Marty. I owe ya more 1
