gstallons Posted March 29, 2017 Posted March 29, 2017 Have ay of you ever used Hylomar ? It is from the UK and it is pretty good stuff . If you have not heard of it , Google and spend a few hours .
bbolesaz Posted March 29, 2017 Posted March 29, 2017 BMW Airhead guys live and die by Hylomar. Personally, I prefer Yamabond #4, I think it works better on Alu than Hylomar. Available from your local Yami dealer.
gstallons Posted March 29, 2017 Author Posted March 29, 2017 Watch some videos , I think you will be getting some and using it .
swooshdave Posted March 29, 2017 Posted March 29, 2017 Yamabond, or Three Bond or the equivalent. But there are places that Hylomar would work better, especially were you have to remove the part often.
pasotibbs Posted March 29, 2017 Posted March 29, 2017 Blue Hylomar was/is Rolls Royce approved (I think Aviation and Car)
czakky Posted March 29, 2017 Posted March 29, 2017 It's good stuff. Stays soft cleans off relatively easy.
gstallons Posted March 29, 2017 Author Posted March 29, 2017 You can use it on any mating sufaces you want . It is this good. You can use it with a gasket or as a lone sealant. There is an assembly procedure you must adhere to for it to be effective . 1
Lucky Phil Posted March 30, 2017 Posted March 30, 2017 Hylomar has been around for years and yes it was approved for use on RR gas turbines but I wont hold that agains it. It's quite good but there are many better options around these days, three bond in different forms etc. Ciao
Scud Posted March 30, 2017 Posted March 30, 2017 ThreeBond is a brand name. I have two of their products, based on Pete Roper's recommendation. The products use 4-digit codes as product names. So my tube of ThreeBond 1211 is white, flows easily, takes several hours to cure. My tube of ThreeBond 1184 is grey and tacky and stringy, a little more challenging to apply, but cures quickly. I used it recently on my transmission pre-selector case - filled it with oil and rode it after 15 minutes. When I sealed all the cases on my Scura transmission, I used Permatex Right Stuff, which can be had in grey or black. I also have a tube of Permatex Gasket Dressing and Sealant, which is blue - and they say "compare to Hylomar Blue" on the package. I got that when I was trying to find some Hylomar gasket dressing. There is a dizzying array of sealant options. All the above I used recently seem to be improved over the red or black RTV silicones that I used a long time ago. 1
gstallons Posted March 31, 2017 Author Posted March 31, 2017 There are many good sealants w/varied and specific applications. A person needs to keep an open mind to keep improving.
moto fugazzi Posted March 31, 2017 Posted March 31, 2017 IIRC, Pete recommended it on a leaky seal that I had, and I've been using it ever since. I also use it instead of loktite on small bolts that I don't want to vibrate loose. Ken
Trevini Posted March 31, 2017 Posted March 31, 2017 Been using it for years. It's best for components that need to be removed fairly regularly, such as rocker covers, sump gaskets etc when used in conjunction with the correct gaskets. Easy to clean off too. 1
