TomekSZ Posted April 7, 2017 Posted April 7, 2017 Hey, I have such a problem. Namely, it is about a throttle, which is no longer available in Europe for virtually one cable. They are used alone, which have the same problem of rubbed plastic. Throttle is jamming, practically all the time. I'm trying to do something about it, but I'm wondering if anyone of you tried the domino universal throttle with handles and would it fit? This is the type i wonder about: http://www.domino-group.com/en/catalogue/throttleControls_Detail.aspx?idmaster=2579
gstallons Posted April 7, 2017 Posted April 7, 2017 The interpretation is difficult . Can you explain in detail what your problem(s) is you are having ? Is it the V11 bike or another ?
stewgnu Posted April 7, 2017 Posted April 7, 2017 I've found they are susceptible to bad routing- have you tried adjusting it?
czakky Posted April 7, 2017 Posted April 7, 2017 The plastic cable guide on the single cable bikes is worn?
sp838 Posted April 8, 2017 Posted April 8, 2017 I have a domino throttle. It works fine, but I want one that points down, not to the side.
TomekSZ Posted April 8, 2017 Author Posted April 8, 2017 ok sorry, it is the v11 lemans 2003. And it is the throttle go back problem. "The plastic cable guide on the single cable bikes is worn?" Yes this is the exact problem i have. I must change it with an accessory and the question is if the domino throttle will fit?
TomekSZ Posted April 20, 2017 Author Posted April 20, 2017 Ok the new throttle by domino is great it works very fine, it is much better than the origynal so problem solved
