PJPR01 Posted April 20, 2017 Posted April 20, 2017 Looking delicious Chuck...maybe you can bring some of that to Cedar Vale!
swooshdave Posted April 21, 2017 Posted April 21, 2017 Did you update the Greenie Registry with your new bike yet? http://www.v11lemans.com/forums/index.php?showtopic=18887&page=2
docc Posted April 21, 2017 Posted April 21, 2017 What I do not see in your To-Do List: > Baseline the TPS > Check/ zero the CO Fuel Trim > Balance the throttle bodies > Test/ install a fully charged, correct, battery
Scud Posted April 21, 2017 Author Posted April 21, 2017 What I do not see in your To-Do List: > Baseline the TPS > Check/ zero the CO Fuel Trim > Balance the throttle bodies > Test/ install a fully charged, correct, battery Yup that stuff too. I'll give her a thorough inspection/maintenance. But she's gonna have to wait her turn after barging in all cheap and pretty and unannounced... the sassy little tart.
docc Posted April 21, 2017 Posted April 21, 2017 ... the sassy little tart. That Greenie Attitude comin' out. And with the proper green bikini to match . . .
swooshdave Posted April 21, 2017 Posted April 21, 2017 ... the sassy little tart. That Greenie Attitude comin' out. And with the proper green bikini to match . . . http://www.v11lemans.com/forums/index.php?showtopic=17183 This is all it would take for you to join the Green side... 1
Scud Posted April 21, 2017 Author Posted April 21, 2017 Ha. I KNEW it was candy apple green. Green Delicious. Sent from my iPhone using Tapatalk
Chuck Posted April 21, 2017 Posted April 21, 2017 Looking delicious Chuck...maybe you can bring some of that to Cedar Vale! Thanks, but I'm not bringing enough stuff for cooking for a hundred..
PJPR01 Posted April 21, 2017 Posted April 21, 2017 God no Chuck...I wasn't going to suggest roping you into cooking that much!! Figured you might have one slip in a side bag to be shared surreptitiously around the camp fire!! Shoot...I'll bring a chilled bottle of the yellow stuff to pass run around! 1
LowRyter Posted April 22, 2017 Posted April 22, 2017 yellow stuff? Paul, you empty that out of your tent.
PJPR01 Posted April 22, 2017 Posted April 22, 2017 yellow stuff? Paul, you empty that out of your tent. ROFL !!...Limoncello my friend!!
nwrider Posted April 29, 2017 Posted April 29, 2017 You might want to check the fuel filter/s for partial blockage. That happened to a Ducati 907ie I had -- it would run great below 6k but would bog after that. Turned out that the fuel filter was restricting flow at higher rpm.
Scud Posted April 29, 2017 Author Posted April 29, 2017 Thanks for the suggestions. I might start looking into the Greenie today. One item of note - it has an electric petcock. Should that be replaced with a manual petcock? (I have one readily available).
JRD Posted April 29, 2017 Posted April 29, 2017 I would definitely ditch the lectric and install the manual petcock. Just one less electrical component to worry about. If I recall, some folks were having problems with the electrical petcock failing to open until there was enough vacuum or pressure to activate the switch. The greenie I had and my LM both equipped with manual and never had any problems.
