Cabernet Posted May 19, 2017 Posted May 19, 2017 The sensor is below the filter to the forward right side. What is its' purpose? I am guessing inlet air temp?
Cabernet Posted May 19, 2017 Author Posted May 19, 2017 So. I am scrapping the airbox, in favour of K&N. What do I do with the sensor.
MartyNZ Posted May 19, 2017 Posted May 19, 2017 On 5/19/2017 at 9:25 PM, Cabernet said: What do I do with the sensor.See DD's post here: http://www.v11lemans.com/forums/index.php?showtopic=19831&page=1&do=findComment&comment=218202And this:http://www.v11lemans.com/forums/index.php?showtopic=19764&hl=
Kiwi_Roy Posted May 20, 2017 Posted May 20, 2017 On 5/19/2017 at 9:25 PM, Cabernet said: So. I am scrapping the airbox, in favour of K&N. What do I do with the sensor. I extended mine up near the headstock where it stays cool, I left it there when I ditched the pods and put the airbox back. I cut it apart and soldered the sensor to a pair of wires from a wall wort. You could also use a new sensor from Digikey, send me your postal address in a PM and I'll send you one. Or just put a fixed resistor close to the temperature you ride at. This is the oil sensor but the resistance v/s temperature is the same. 3,000 Ohms for 25 degrees C
68C Posted May 20, 2017 Posted May 20, 2017 Does anyone know why the oil temp sensor screws into the cylinder head and not the oil sump?
Chuck Posted May 20, 2017 Posted May 20, 2017 Because it's a cylinder head temp gauge. Never believe everything you read in a Guzzi manual. 2
MartyNZ Posted May 20, 2017 Posted May 20, 2017 I bought a pack of 10 NTC thermistors, and only used one. I can mail you one if you can hook it up youself. Just PM me with a mailing address. 3 cents plus postage adds up to "you owe me a beer". The attachment says 3,000 kOhms. Depending on how you interpret the comma, it could mean 3000 kOhms = 3MOhms, or 3 point 000 kOhms. As Kiwi_Roy said, 3kOhms NTC measured at 25 degrees C is correct. PS, I still have have an airbox on my bike. I think that there was a good reason for MG to go to all that trouble, when pod filters would be cheaper and simpler to fit. 1
Cabernet Posted May 23, 2017 Author Posted May 23, 2017 Thanks all. I get the gist. Appreciate the responses.
GuzziMoto Posted May 31, 2017 Posted May 31, 2017 On 5/23/2017 at 12:02 PM, Cabernet said: Thanks all. I get the gist. Appreciate the responses. I do understand the desire to get rid of the airbox, the open airy look is sexy. But it is a trade off, the airbox actually helps the bike run better and make more power. You can get rid of the airbox, but it will take some work to get the bike close to back to where it was as far as running well. It is unlikely it will ever run better than it did with the airbox (in reality, if it did run better without the airbox it would be because the bike was not running 100% right with the airbox). There are some who have removed their airboxes and got the bikes to run pretty good without. But it is a trade off. 1
Kiwi_Roy Posted June 1, 2017 Posted June 1, 2017 I reckon what makes the stock air-box run so good is the intake rubbers between the throttle body and air-box These are like Velocity stacks. I used these to extend my pods and it removed the flat spot.
