68C Posted June 28, 2017 Posted June 28, 2017 Hi all, bit of silly question, I need to replace my oil pressure switch but having trouble finding the spanner/socket size, access not good with tank and fairing on and did not want to strip bike down until I knew I had the right tool. If anyone has the switch to hand perhaps the could measure it for me. It seems to be around 22mm.
luhbo Posted June 28, 2017 Posted June 28, 2017 I think it was the one. I remember it was something easy.
68C Posted June 29, 2017 Author Posted June 29, 2017 Just to update this post in case anyone looks at it in the future. Got the oil pressure switch out, measures up as 21mm. I tried a 13/16" standard UK plug socket, would not fit. In the end I used a Snap-On 7/8" plug socket from my aircraft toolbox which worked fine. I did notice the switch is very close to a raised part of the engine block so a cheaper socket may need grinding down a little. To be fair to you Luhbo, I believe continental Europe uses 21mm as a plug wrench, the UK and probably others use 13/16". The switch was very tight, needed the socket with an extension bar and a 2 foot piece of pipe to shift it. As it was so tight and as it has the round connector I assume this is the original switch
luhbo Posted June 29, 2017 Posted June 29, 2017 You made me look it up, man. Indeed we have 21mm plugs and wrenches, or should I say "luckily" 13/16 equals 20.6, by the way. 1
68C Posted June 29, 2017 Author Posted June 29, 2017 That 0.40mm makes all the difference as the lady sitting on my bike says.
luhbo Posted June 29, 2017 Posted June 29, 2017 .. what answers another question I "Always Wanted to Know []But Were Afraid to Ask" This morning I made 60km in heavy rain, the pressure light brightly on for nearly the whole distance. What's the problem with your's? Hubert
68C Posted June 29, 2017 Author Posted June 29, 2017 Replaced the oil pressure switch with a BMW320 car item. My local auto parts shop supplied it as a Cambiare VE706070 which had a flat connector. I cut the round stud off the old switch to make up a short adapter lead, pleased to see that revealed it was hollow which made soldering a wire into it easy. Crimped a flat female connecter to the other end, a little heat shrink and Bob's your auntie's live-in lover. Oil pressure light now works OK, ignition on-engine not running = light on. Engine running = light out. Suprised it took about five seconds for the light to come back on when I stopped the engine, guess that is a good sign.
Kiwi_Roy Posted June 29, 2017 Posted June 29, 2017 Spanner, can't be from around here LOL Sent from my shoe phone!
docc Posted June 29, 2017 Posted June 29, 2017 Spanner, can't be from around here LOL Aaaaah! "Chiavi!" ( > "keys"
luhbo Posted June 29, 2017 Posted June 29, 2017 ... Suprised it took about five seconds for the light to come back on when I stopped the engine, guess that is a good sign. That was probably a cold engine. In the morning I can watch the same, on hot days' evenings and/or after some Autobahn rush sometimes the light flickers at low idle already (100°C). Nice find, by the way. In most shops nowadays it's nearly impossible to get a spare part just by description. Either you have a correct number or the car documents or you're wasting your time.
luhbo Posted June 29, 2017 Posted June 29, 2017 Spanner, can't be from around here LOL Aaaaah! "Chiavi!" ( > "keys" Look up 'Chiave Inglese' - we call that 'Franzose'
Chuck Posted June 30, 2017 Posted June 30, 2017 Suprised it took about five seconds for the light to come back on when I stopped the engine, guess that is a good sign. Yes it is. On an aircraft with (naturally) a mechanical oil pressure gauge.. watching how slowly pressure bleeds at shut down is a good sign of how good the main bearings are. 5 seconds? Pretty good.
