Dadparent Posted July 30, 2019 Posted July 30, 2019 Hi Docc, as a result of your information about my clutch-question last week I came here. In my clutch-set there is a new pinion and now I want to ask you with which torque is the nut (SKF-KM5) fastened ?
docc Posted July 30, 2019 Author Posted July 30, 2019 I’ll be back to my Workshop Manual in a few hours and will check. This is the special nut that holds the input hub to the gearbox and requires a special tool to tighten before securing with a tab from the Safety Washer?
Dadparent Posted July 30, 2019 Posted July 30, 2019 Yes indeed. that's the one. When I loosen it it was not so tight, but I found that suspicious
docc Posted July 30, 2019 Author Posted July 30, 2019 Yes, the torque is high on this and requires both the special drive tool and the safety washer engaged.
docc Posted July 30, 2019 Author Posted July 30, 2019 From the Workshop Manual: " Ring nut for gearbox main shaft, clutch side 100 Nm " The failed Safety Washer is what caused my clutch to malfunction.
docc Posted February 26 Author Posted February 26 Update on these retention washers and special nuts, courtesy of @pete roper: 1
