I am getting ready for a trip and want to purchase a spare crank sensor, I figure its the one part of the ignition you cannot jury rig.
Can someone tell me the Automotive equivalent like which make and model uses it?
For anyone who has changed the sensor, how did you connect it to the ECU, according to the schematics it seems to be wired directly to the ECU connector.
http://www.thisoldtractor.com/guzzi007/schematics/1999_V11_sport.gif  item (53)
Or is the plug 1,2,3 hidden somewhere ib the loom?
Never mind, I googled SEN813 and found it
Fiat, Lancia, Alffa Romeo
I think Ducati use it also  Update - the parts guy showed me a picture it had just one screw hole hard to seal the oil in I think - Roy
Copied from another forum
http://www.ebay.co.uk/itm/CRANKSHAFT-SENSOR-ALFA-ROMEO-145-146-1-4-FIAT-Tempra-Tipo-1-8-LANCIA-/251703577340?
This is the exact same part mine arrived quickly direct fit £24.96 as opposed to over £130 from Guzzi I had to really look hard for it I have told the seller and he is going to add the Bike  OR SEN-813 to make it easier to find this sensor is fitted to a whole load of Guzzis V11 series and all these
I think I will take a trip to the local auto wrecker, I might be able to find the mating 3 pin connector as well.
I just bought one via ebay from Latvia that was cheaper by half than buying a guzzi one in Australia.
Sent from my SM-G930F using Tapatalk
Spent a fruitless afternoon checking out the dealers
The Auto wrecker would only sell me a complete engine
The Fiat dealer wanted the Vin number
Also checked a couple of after market parts shops
The Ducati guy had a picture but their sensor was held by just one screw
None of the above could cross reference the Magneti Marelli part No SEN-813
Still, I had a good ride on the old Eldo, you don't get that shopping on-line
Yes I saw the listing on Yoyo parts, I'm not convinced they actually have one though
I ended up ordering one from Boonstra Parts in Holland
Off an MV Augusta Brutale 750, the Guzzi has to be happy about that.
Cross Interchange Parts
Factory Number
MEAT & DORIA 87074
HOFFER 7517074
FAE 79015
SIDAT 83.125
FISPA 83.125
Auto Part
ALFA ROMEO 60603937
FIAT ???????
Czakky - Lets get the Fiat part No in there as well before putting it in the cross reference
There has to be more fiat dealerships than Alfa Romeo
http://www.yoyopart.com/oem/8484462/magnetimarelli-sen813.html
If you scroll down on that page it shows a bunch of Sku numbers related to different cars, I will try those over the weekend.
Scroll even further it lists the vehicles it was used on
I can't post links from here but I stumbled across an interesting post from Bill D
http://archive.guzzitech.com/PhaseSensFail-Bill_D.html
In particular paragraph 4
This gives a good diagnosis of the sensor failure, he noticed the Tach dropped off and backfiring even though the motor was still spinning, I thought that was brilliant.
I'm sure Bill won't mind me linking to it here.
