plexiform Posted August 19, 2017 Posted August 19, 2017 Anyone know what this noise is? Seems to be getting worse. Has been present for some time now. Bike feels fine while running. https://m.youtube.com/watch?feature=em-upload_owner&v=XpToBiy6e_4
docc Posted August 19, 2017 Posted August 19, 2017 First thing, you can remove the forward facing plastic cap over the brake pads and use a brake parts cleaner to clean that area out. Better yet, remove the caliper, remove the pads and inspect their thickness and wear. Using brake parts cleaner, chock one piston and work the other in and out, cleaning with the spray. Repeat with the other piston. Clean, polish, and lubricate (silicone grease) the pad guide pin. Bleed the fluid with the nipple facing upward. 2
docc Posted August 20, 2017 Posted August 20, 2017 It's also worth pulling the wheel and feeling that the wheel bearings and rear drive bearings turn smoothly. Third thing: shaft lubrification. 1
coreytrevor Posted August 20, 2017 Posted August 20, 2017 I agree with the brake making the noise. Easiest way to check, take out 2 caliper bolts, remove caliper, see if noise goes away. I don't think bearings or anything internal would sound like that. 2
Chuck Posted August 20, 2017 Posted August 20, 2017 Yep rear brake. My Centauro freaked me out the first time it did it. 1
plexiform Posted August 20, 2017 Author Posted August 20, 2017 Thanks for the input. Will service the brakes and report back.
Cabernet Posted August 22, 2017 Posted August 22, 2017 Concur, it is the rear brake groaning. Sent from my D5803 using Tapatalk
plexiform Posted September 13, 2017 Author Posted September 13, 2017 Sound is gone. Bled the rear brake and changed the pads and cleaned the caliper and rotor. Used 5.1 fluid for replacement. Pads are now EBC.
