My manhole cover on my sump is weeping, I would like to snug it up, any idea what size that hexagonal socket is?
Because of the rounded corners I can't get an accurate measurement.
Anybody know?
Same as the axle nuts which can be pressed into tool service.
Thanks.
Turns out that the Guzzi tool kit has a wrench that sort of fits.
It also turns out that the weep was coming from the drain plug, which I managed to squeeze another 1/16 turn closed.
Hopefully, that stops it. Next oil change I will change the funny brass & rubber sealing washer.
