guzzi323 Posted October 6, 2017 Share Posted October 6, 2017 I was lubing the driveshaft (off the bike) during a tire change and I noticed a pinhole at the back of the mid-shaft which allowed grease to come squirting out as I pumped it in. It's inside the yoke where it connects to the shaft. I thought it might have come from when I was greasing the rear fitting but I cleaned it off and re-greased the center section. I could hear it oozing out the pinhole. I think it's not a big issue as I can manually smear grease on the splines of the half shafts but it's one more thing to keep an eye on. Link to comment Share on other sites More sharing options...
Scud Posted October 6, 2017 Share Posted October 6, 2017 I've lubed a few of these, and each one allows grease to escape in the same area. I think it's by design. If you put too much grease and it can't escape then you are changing the alignment of the whole drive system. 1 Link to comment Share on other sites More sharing options...
coreytrevor Posted October 7, 2017 Share Posted October 7, 2017 I would think the hole serves the same purpose as the cap some shafts have there that will pop out if you over-grease it. If there was too much grease and the shaft hydro?locked and couldn't compress when it needed to I imagine there could be spectacular and instantaneous destruction to the transmission and/or final gearcase. 1 Link to comment Share on other sites More sharing options...
guzzi323 Posted October 7, 2017 Author Share Posted October 7, 2017 I'd think if it was a 'pressure relief' it would be not right near the nipple. I can't imagine much grease gets down the length of the shaft splines before the grease comes out the end. No matter for me. I'll just manually grease the shaft splines whenever I change the tire. 1 Link to comment Share on other sites More sharing options...
MartyNZ Posted October 9, 2017 Share Posted October 9, 2017 As Scud says, there is an escape hole in the grease cavity on every driveshaft. Normally the drive shaft length extends and compresses a little during suspension travel. This is the reason that the sliding spline exists, and it needs lubrication. I can think of two reasons why you need that little hole. 1. If the grease cavity was full of grease without an escape path, then it is possible to get a "hydraulic lock", which would make something bend or break at the next bump on the road. (at a guess, I'd say the gearbox top mount). 2. Grease is mostly oil mixed with a thickener, so as the oil seeps away, the remaining thickener needs to be flushed away by fresh grease. That little hole allows that flushing to happen. Link to comment Share on other sites More sharing options...
