68C Posted October 18, 2017 Posted October 18, 2017 http://www.ebay.ca/itm/Tacho-Speedometer-Moto-Guzzi-V11-Cafe-Sport-ITI-10-000-Miles-Very-Rare-/282689929232?hash=item41d1a20010:g:jAUAAOSwhZpZ3cA8&vxp=mtr There is one. Perhaps that works for you. I bought that one, had to send it back as it had the common failed mileometer. Gear wheel worn, the needle indicated so the speedo part probably works. He refunded me OK, although I lost out on the return postage. He may relist it as u/s, may be of some use to add a mph dial to a kph item.
Troutman Posted October 18, 2017 Author Posted October 18, 2017 Never mind, I went to the website and RTFM. It's the function/setup button switch. Correct...always RTFM
Troutman Posted October 18, 2017 Author Posted October 18, 2017 You'll probably need new fork springs after saving all that weight. Seriously - that's a good find on that speed sender unit. If I know about that, I would have used it instead of buying a more expensive GPS speedo when I did my Speedhut gauges. Once you verify that it sends a signal from transmission to electronic speedo, maybe you could add it to our Encyclopedia of Compatible Parts? Will you be able to cover the gauges - or just leave them open underneath the flyscreen? John at ETB already tested it and said it worked fine..I sent it to him for that reason. Hoping to cover the gauges back up, very easy to install if you don't as you can use the two angle brackets supplied with it but you can't use them and reinstall the covers. I'll take some photos and post what I do tomorrow.
Scud Posted October 18, 2017 Posted October 18, 2017 Here's how I re-used the rubber mounts on my 2003 LeMans that originally had ITI gauges. The metal parts are all from the electrical section of a a hardware store. You can adjust the height of the cross bar on the threaded lamp rod and align the mounts on the slots with lock washers. I think that image, and several others got PhotoBlocketed on the Speedhut thread. I need to restore those at some point.... I hope this helps you though. edit: not sure what's gone wrong, but I can't post a picture right now. If you want to see how I did it, send me a PM with your e-mail and I'll send the pic directly to you. 1
coreytrevor Posted October 19, 2017 Posted October 19, 2017 I can see it. That looks like a great solution.
Troutman Posted October 19, 2017 Author Posted October 19, 2017 That's pretty much what I will do only these ETB gauges have 2 posts not 1 like yours. So I will fix another blank plastic disc to them and then drill new holes to fit the M4 dampers. I'll put some photos up soon.
Scud Posted October 19, 2017 Posted October 19, 2017 FYI - the Speedhuts didn't have any posts. I glued the lamp-nuts onto the backs and screwed the posts into them. The crossbars are what you use to mount lights into electrical boxes on the wall or ceiling.
Troutman Posted October 19, 2017 Author Posted October 19, 2017 So i've hit a big hurdle.. I was under the impression the Acewell S4/Daytona speed sensor would screw straight onto the boss coming out the gearbox...well it doesn't! the male thread from the gearbox is much larger, maybe M14 not M12 like the Acewell. What's more you can't get a sensor that will have an M14 female end on it so it looks like some fabrication work is required. The good thing is that the sensor has no resistance at all so with the knurled nut removed somehow it could be held in another way, I was thinking heat shrink tube or something like that. It's very tight in there too, very close to the throttle linkage. 1
Troutman Posted October 19, 2017 Author Posted October 19, 2017 Ok so I've been and had a look at things and I've come up with a plan. I decided to remove the rubber casing/jacket thing around the Daytona/Acewell unit, I did this very carefully with a new blade in my scalpel not going right through just part way and then tearing it. This allowed me to slide the M12 Cap up the cable and one at a time over the bullet connectors so we end up with this. The cable can now be carefully bent down very easily and kept out the way of the throttle linkage above. Next was to remove the old speedo cable from the bike and cut the end off so I could remove the large cap and collar/insert thing. The plan is to use this to slide down the new sender unit and use it to fix to the bike ...only small snag is the collar/insert needs drilling out from 8mm to 9.5 so it can slide down the body of the unit and get held by the flange. I might saw the very end off the small cap as it was made for this. I'll carry on later after a cup of tea. Everyone keeping up? If there is anything that doesn't make sense please shout up and i'll have a go at explaining better. 1
Troutman Posted October 19, 2017 Author Posted October 19, 2017 I drilled the collar out to 9.5mm, enough to let it slide down the sender body but stop at the end flange..picture explains it. Fits in now This is what i've done with the speedo. I cut a plastic disc out using a 79mm hole saw ( I had one amazingly) from on old 3phase junction box I was going to chuck out. Then mounted it to the ETB screws and after much messing about managed to mark and drill the holes for the Guzzi cover. Just need those M4 dampers now. 5
polebridge Posted October 20, 2017 Posted October 20, 2017 It's www.digital-speedos.co.uk , i got mine last week so hopefully they still have them. I think it was £26. DAYTONA M12 Type M Cable Drive Adapter Thanks Troutman!!! I just order one.
bbolesaz Posted October 20, 2017 Posted October 20, 2017 Anyone got a line on a sensor that actually fits? My bike has a 45 degree adaptor that keeps the cable away from the FI linkage. Is that missing on yours?
docc Posted October 21, 2017 Posted October 21, 2017 There are some senders depicted in the "Installing SpeedHut Gauges" thread. Some of the images are damaged. http://www.v11lemans.com/forums/index.php?showtopic=19038
Troutman Posted October 21, 2017 Author Posted October 21, 2017 Anyone got a line on a sensor that actually fits? My bike has a 45 degree adaptor that keeps the cable away from the FI linkage. Is that missing on yours? Well this does fit..It took me about 10mins to do, it's very easy. You just need a 9.5mm drill bit and a way of holding that collar, i did it in my press. It's a 3 core cable coming out , it's 5mm diameter, very easy to manipulate out the way of the linkage. The actual unit is tiny, look at it in my dirty fingers, it's about 30mm long. No need for machine work or adaptors. I'm thinking of going forwards with mine so under the FI unit. 1
Troutman Posted October 21, 2017 Author Posted October 21, 2017 The wiring is very simple too. I took power and earth from one of the two bulbs that came out the ITI unit. The green is power for the ETB speedo so I doubled that and put a male bullet connector to connect for the Daytona sensor. Same for the Earth. The Yellow Signal from the Daytona sensor plugs into the ETB Yellow which makes it easy. That's it! There's a hole load of other wires for various inputs into the ETB speedo. I just tied these up. The little button I am going to put up through the left handlebar hole in the tope yoke (this is because mine has had clip ons fitted so the original handlebar holes are still there). This will mean I don't have to drill that lovely dash. The M4 dampers arrived today so I'll get on and fit the speedo now. £5 from eBay. 1
