For anyone so inclined.........Airtech Streamlining makes replica Ghezzi & Brian fairings and one piece tank/seat/rear cowl assemblies at very reasonable prices too! :whistle:
(scratching head)I wonder how they carved 75 ! pounds off of it.
Lighter frame, wheels, bodywork... shall I go on?
http://www.airtech-streamlining.com/guzzi/ghezzibrian.htm
Rough math has it at $625? Then you would have to get it painted and build the framework to mount it. And seat upholstered. Totally worth it! Now I just need to find a rough V11 or 1100i...
No foot bail on the side stand, no eagle badge on the alternator cover . . .
"Take care of the ounces . . . ."  ;)
Wish I could photo play just to see what a v-11 Sport or LeMans would look like with a stock tank and seat with the Ghezzi fairing.
Even just putting the fairing on would take some mad fab skills. There would be a fairing bracket to hold the lights and mirrors and support the front of the fairing.  Could start with a LeMans piece and cut and weld.  Then, where would you source that headlight from.  Probably G&B used an off the shelf Japanese or Ducati unit, but you'd have to find out what it was.  Maybe a few more brackets from the frame to the sides. Etc, etc.
Oh, it would be an adventurer, but if you were handy with a welder or knew someone who was...
That is the only way you would get it to fit. The fairing just wouldn't go with the stock tank. At all.
I was wondering why a nut on both ends of the rear axle, then I saw that they double as spools for a rear stand.
  On 10/12/2017 at 2:37 PM, brubache said:
Oh, I hadn't seen it in red before. I may need to lay down.
122_0012_01_z%2BGhezzi-Brian_supertwin_1
  Quote
The Supertwin uses the five-speed gearbox from the California instead of the V11's more modern six-speed box because Guzzi originally refused to supply the new unit. Mandello bosses recently had a change of heart, Giuseppe says, but by then it was too late because the reshaped six-speed transmission would not fit in the Supertwin's frame.
